1 ton axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dave, Jul 9, 2000.
  1. Dave
    Dave Registered Member
    Apr 23, 2000
    63
    Grafton, Wisconsin
    I just want to be sure, before I make the offer that 1 ton axles out of a 1980 pickup (single rear wheels) are 14 bolt. And how do I distinguish if they are full floating, or just semi floating???? The farmer across the street from me just "retired" his '80 K-30, and I think I hear opportunity knocking on my door :)
    Dave Hiller
    90 K-5
    "The Anti-SUV"
  2. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Go to the home page and look under technical, and there will be an axle identification chart
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Not sure, butyoucould walk accross the street and count the bolts that hold the cover on the pumpkin.
  4. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    but-you-could
    sorry, my space bar is not working too good
  5. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Semi floating will not have a hub sticking out from the center of the wheel, Full Floater will stick out about 4 inches or so, and weigh in at a measly 600 pounds.[​IMG]
    <font color=blue>White Knight</font color=blue>
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Also go to the axel swap how to section on the main page it has many color photos of a 14ff up close and personal.
  7. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    First off the full floating rear will have hubs sticking out instead of a c clip that is inverted and is much larger
    also a true one ton has 13 inch rear brakes stamped on the
    inside drum housing. If they are smaller it is not a one ton
    rear. The front will say 60f on the right side of the pumpkin facing the front of the truck. Brian
    MUDNUT
  8. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    If it says K30 or 3500 and it's 4wd-it'll be a 14 bolt FF.
    By the way , they call it a 14 bolt because there are 14 bolts that hold the ring gear on the carrier not just the the inspection cover
