1 Ton axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dave_90_blazer, Jan 24, 2004.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    OK, I know that to use a 1 ton rear in a 1/2 or 3/4, you need to move the spring perches and shock mounts, but is a 1 ton front (D60) the same as a 1/2-3/4 ?
    i.e., a 100% direct bolt-in (not counting u-bolts/plates and D/S)
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Yes, it bolts right in.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can use a 3/4 ton rear axle and put on 1 ton brakes and have your 1 ton rear without having to move anything
    good luck
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    good luck
    He asked if the front was bolt in, not the rear.
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    good luck
    See why he added that post now /forums/images/graemlins/wink.gif No more cutting and welding if you use the 3/4 ton axle and the 1 ton backing plates everything, including the e-brake will be a direct bolt on application for the rear also. Hmmm... sounds like useful info to me /forums/images/graemlins/thumb.gif
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    And it works good too! /forums/images/graemlins/thumb.gif
    Started with a '75 C20 14FF w/3.21 ratio, added '91 V30 backing plates, and '82 C30 hubs/drums. Direct bolt-in 1-ton rear for my '84 Burb. /forums/images/graemlins/ears.gif
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Am I stupid or is his only question about if a front D60 bolts in? He said he already knows about the rear.
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea ur right..but i think he was also telling im in case he didnt already know, that there are other ways to have a 1 ton rear end with out having to move spring perches/shock mounts..
    pad /forums/images/graemlins/rotfl.gif
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If it was me I would not run the humungous 3.5" drums because they are heavy and a lot of brake for a 1/2ton proportioning valve. My large enough 2.5" drums wan't to lock up too soon already, I bet it would be terrible with 3.5's. /forums/images/graemlins/thinking.gif
  10. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I like my humungous 3.5" brakes in the rear. They work well when you have a tire over 35" tall and need to stop quick.
    I also like the fact that I had an e-brake hooked up when my 39" tire came off the bead taking out my front brake line leaving me with no line pressure. I have hooked up the e-brake on 3/4 ton brakes with the 2 bolts, but it's a little more work. Mine were a direct bolt on this time.
    why did I even reply to this hijacked thread anyways? /forums/images/graemlins/confused.gif
  11. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    I have to say with bigger tires...The real reason that I am going won ton is mostly for the brakes !!! , but the 411 gears helped too.. /forums/images/graemlins/ooo.gif
  12. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    When I go for "Won ton" it's usualy when i am hungry.
    Sorry man, I couldn't resist.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Won ton is chinese food. /forums/images/graemlins/thumb.gif
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I was thinking the same thing. /forums/images/graemlins/rotfl.gif
  14. bigjohnintexas
    bigjohnintexas Registered Member
    Oct 17, 2003
    17
    East Texas
    The D60 is a direct bolt in, but be aware that it will give your front end almost an inch of lift because the difference in height of the pumpkins where the spring bolts to. I liked the extra tire clearance it gave me, but some people might not.
