1 ton Brakes
Discussion in 'The Garage' started by txfireman110, Mar 6, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    When I do the 1 ton swap, will it eliminate the braking problems that I have heard about when someone puts the 14ff in w/o the D60? /forums/images/graemlins/dunno.gif
    Also, I plan to go to discs on the 14ff but maybe not right away so what will it do both ways?
    Last ?; Do I need to swap in a one ton master cylinder??
    Thanks /forums/images/graemlins/tongue.gifeace
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    what braking problems are you refering to?
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Im running a 14FF (drum brakes) with my stock manual master cylinder, no problems....you should be fine to run with drums with your existing brake system as far as I know. /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    whoever you hear that from dont listen to them anymore
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The only braking problem related to a 14FF is the stop you make when they tell you how much a friggin drum is. And then they have the nerve to tell you that is not for the pair. The only probelem found so far is with 4 wheel disks needing more fluid. You can just use a bigger master cylinder for that though.
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Brandon,
    Bolt it all up, bleed the brakes and test it out. When we did the swap the only problem was getting the whole system bled properly, after that everything functioned properly.
  7. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    I was refering to a few posts saying that the bigger back brakes would lock up prior to the front! /forums/images/graemlins/dunno.gif
    PS-Thanks for the replies
  8. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    It seems that everyone has different experiences when they do the swap, some like they way it stops and some dont. And most do say that the rear does tend to lock up before the front. You can always change the brake bias with an adjustable proportioning valve, like a Wilwood
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just bled my brakes and drove it for the first time with 1 tons and discs. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif No problems with the stock 1/2 ton master.
  10. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i think it should be fine, however, if you convert it to disc, i imagine you will have to get rid of your proportioning valve, which sends more power to the drums because they require more power to be effective, and another valve called something like a delay valve (if i think about it ill look it up tomorrow) which sends power to the rear drums before the fronts so they will in turn activate simultaneously, since drums are slower too. but ive never done the conversion, it just makes sense to do that...
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is good advice. Before I did my D44/14BFF swap, I did alot of reading and determined that the best route was to swap axles and see what kind of brakes I end up with. I gravity bled the rear brakes (I reused the front calipers, so no front bleeding was needed) and then went for a ride. I had great brakes. Even with the discs, no prop valve was necessary. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
