1-ton calipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mountainexplorer, Feb 24, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have a pair of front brake calipers off a 1-ton 2wd. They look the same as the ones on a Dana 60 front. Does anyone know if they are interchangable?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    call auto zone, or look on theier web site and check the same year as a 4x4. if the numbers are the same use them.
    Grant
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I tried the 1/2ton setup on my half ton axles, and they fit but the purging area has a hump that will not clear when turning.
    I hope the 1ton setup isn't the same.
    You could try and see.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If not, you might be able to get some new ones from the parts store and use those as cores. Most parts guys would never notice. New ones with a core should only run about $12 each or so.
