1 Ton D60 + 14BFF conv.
Discussion in 'The Garage' started by landcrusher, Feb 26, 2004.
  1. landcrusher
    landcrusher Registered Member
    Jan 21, 2004
    33
    Escondido, CA
    Looking at the possibility of swapping in a 1 TON D60 and a 14 Bolt FF on my '84 Sub.
    I currently have a 10B front and 14B SF rear.
    What do I gotta do to get this done? /forums/images/graemlins/dunno.gif
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    If you get a 1 ton 14 bolt FF all you wouild need to do is move the spring perches. I am not sure which way or how far you will need to move the perches on the 14B. If you find a 14B FF out of a 3/4 ton, it will be a direct bolt in. The D60 is a direct bolt in. I hope this helps you out. /forums/images/graemlins/thumb.gif
  3. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    The D60 is a direct bolt in? Does this include the caliper fittings, shock mounts, and driveshaft hookup?
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Yes...
    Rene
  5. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    Sweeeeet! /forums/images/graemlins/waytogo.gif
    What about the 14B FF? Does the driveshaft bolt up? Brake fittings? Shock mounts?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You need a cinversion u-joint http://coloradok5.com/forums/showflat.php/Cat/0/Number/548638/page/0/view/collapsed/sb/5/o/all/fpart/1
    The Napa PN 447 is a 1330-1350 combo joint used in going from a 10 bolt to a 14 bolt.
    The Napa PN 348 is a 1310-1350 combo joint used when going from 12 bolt to 14 bolt.
    Courtesy of muddytazz post at above.
    I know when my buddy used a 1970's 2wd drive axle all shock mounts etc still worked fine. If the brake lines dont match the ends that go into your hose, you could cut and re-flare on the end and your fittings can be used. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  7. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    Can't see post link.
    What about a 14 bolt SF to a 14 bolt FF?
    I have the large 13" brakes on the SF now, so I'm hoping the FF brakes are the same. ...???
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Brakes are different as the 14bsf is like a 10 bolt kinda and 14bff has different hub arrangement. I believe the 14bsf u-joint is same size as 10 bolt. If not someone should reply to ya otherwise. /forums/images/graemlins/thumb.gif
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    The 14SF 3/4 ton version is a 1 ton (1350) U-joint.
  10. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    If I'm understanding correctly; my 14B SF 3/4 ton driveshaft should then bolt right up to the 1 ton FF!?
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Cool, glad you knew that , I wasn't sure. I saw a 14bsf that took 10 bolt u-joint once. So now I know too /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  12. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    What about spring plates and U-bolts?
    Are these the same from a 10b to a D60
    & a 14b SF to a 14b FF? Gotta know if I need to pick these up as well.
    The direct bolt in for the D60 seem too good to be true. There has to be something I'm going to get stuck on!
  13. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    The spring plates for the D60 are totally different from the 10B, and you D60 will also need new ubolts.
  14. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    The pinion snout is also much longer on the D60, but this is often times offset by a lift.
  15. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    Okay; new pring plates and U-bolts for the 60.
    What about the 14 SF to FF. Are the axle tubes the same size? Same U-bolt & plates?
    I have a 6" lift now and my double Cardan already clacks the T/C crossmember. The longer D60 snout sounds like it will cause more problems. $#!T /forums/images/graemlins/angryfire.gif
  16. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    Another question:
    Is the track width different using 1 Ton axles from 3/4 Ton.
    It also seem that the 14b FF shock mounts are located differently. I'd have to move the spring perches anyway, so thats just another step.
