1 ton ff14b swap to sub
Discussion in 'OffRoad Design' started by gambit420s, May 24, 2005.
  1. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    will ord part GU38011 allow me to swap a 1ton ff14b if i use the stock 1ton front hangers? or should i move spring perches?
    i'll be replacing 89 sub sf14b with a 80 1ton ff14b
    does it matter that the ff is from swr 2wd?
    anybody else done this?
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Why would you change the spring hangers? Just grind the spring pearches on the axle and weld them in the new spot. Buy the bushings for whatever springs you have :burb:
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You'll need to use the right flip kit for your truck and move the spring perches, if you use the 1-ton flip, you'd have to change the front spring hangers to match and might have other problems with the springs being closer to the frame. Overall it's easier to move the peches and shock mounts.
  4. gambit420s
    May 17, 2005
    294
    yeah thats what i was thinking about the perches
    but i just found a 3/4 ff14b for $10 so ill prob just use it
    oh well thanks alot guys :bow:
