1 ton gear ratios?
Discussion in 'The Garage' started by baddane1, May 3, 2004.
  1. baddane1
    baddane1 Newbie
    May 3, 2004
    Hi i am new to the forums here. I am going to buy aa 1979 1-ton 4x4 to play with. My main ? is right now is what are the front and rear gear ratios? It has a 350 with a 465 trans and 14 bolt with a dana 44 in the front and i am unsure of the t case also. What normally came in these as far as the gears and the T-case?
    Thanks,
    MJ
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    WELCOME TO CK5 /forums/images/graemlins/waytogo.gif
    Tcase: NP205
    Front axle: Dana 60
    Gear ratios: 3.73, 4.10, 4.56 - with a 465, I would say probably 4.10, but it could be any of those.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Gear ratio will depend on how the truck was ordered. 3.73, 4.10 and 4.56 were all options.
    If that truck does have a Dana 44 in the front, someone robbed the best part out of it. I've seen alot of 1 tons get the Dana 60 taken out and a Dana 44 put back in its place to be resold.
