1 ton lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scotto0609, Mar 16, 2007.
  1. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    I have a 85 bigblock no air crew cab dually and would like to lift it just 2-3 inches. I dont want to loose any capacity because it carries a @3500 camper on it. Anybody have any suggestions on brands. The plan is for rancho 9000 shocks,rear blocks so I can keep the overloads in place,and the recommended front springs. Also not going 4' because I only am going with a 305 tire and dont want to put a block in for steering correction. thanx
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Leave the stock springs alone and install zero-rates front and rear along with a 1" or 2" body lift.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you like the ride and just want tp put 305's put a 1" or 2" body lift, it'll be cheaper, maybe a little easier depending on how bad your body mounts, bolts are, and the ride will not change
  4. scotto0609
    Feb 3, 2004
    1,526
    3
    babylon,ny
    Didn't think about zero rates but I forgot to mention the springs are only about 2 inches off the bump stops and that camper on the beach can really torque the truck over. As far as the body lift ,I believe that would be harder to install than front springs. Thank you for the input.
  5. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    also if you do want the body lift and are thinking about the blocks in the back ditch them and go get some 1-2" square tube and run this the whole length of the box for the lift to help support the camper better. you will need to mark and drill the holes threw it to be able to pass the bolts down threw. but this will suport the under side of the box much better than just the spacers.
    also take in to acount the added body flex on the longer bolts and the big camper. i would possible go 2" hd springs frt and 2" block cast iron or solid in the rear.
    your choice but just some good points.
  6. scotto0609
    Feb 3, 2004
    1,526
    3
    babylon,ny
    Anybody manufacture a hd 2" lift. I looked at most lift companies and didnt find any listings for 2" hd.
