1-ton lug nuts... DUMB Q
Discussion in 'The Garage' started by KRAZIE87K5, Feb 16, 2004.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    guys, sorry for this one. I'm heading to Pepgirls to get some new lug nuts, and wanted to know what thread pitch I should be looking for. I'd bring a sample along, but the truck is 1hr away at a friends place... and I'm not sure if I have any spares in the garage. /forums/images/graemlins/doah.gif
    Anyone?
    -Dan
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    aren't 3/4 and 1 ton lugs just 9/16" course thread? I know I was using some standard course thread nuts off of ubolts on my 14bff for awhile. I don't know about pitch.
    oops. ment fine thread
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They should be 9/16 fine, or if it is dodge parts and 1990 or newer 1/2-20 (fine)
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I know they are a 9/16" thread, but do not know the pitch. I also know that pepboy's will not have them, you should hit a local part's store or napa, if they do not have them, they can get them from a local warehouse, just tell tem they are for a K30 and you should be set.
  5. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Just go to your local tire/wheel shop. They should know (after looking in the computer) and you can buy as many or as few as you want. Most automotive studs are fine thread.
  6. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    If they are the same as a 3/4 ton, then they are 9/16"-18 thread.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    9/16" fine thread 60 degree conical seats. /forums/images/graemlins/waytogo.gif
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Thanks Westy! Suppose the 60* thing is still accurate when mounting hummers? /forums/images/graemlins/woot.gif
    -Dan
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    My 78' Ford 60 has 1/2" studs up front. I will be changing them to 9/16" soon.
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    My old 80' SRW hubs had 1/2 fine lugs too before I swapped to these DRW hubs from the late 70's. Now they match the studs that are in my DRW D70, which is supposedly 9/16 fine thread.
    -Dan
  11. Stomper
    May 11, 2002
    3,767
    Iowa
    Yea, they are 9/16" 18 TPI /forums/images/graemlins/waytogo.gif
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    -Dan
    AFAIK, there is no other degree of conical seats except for the mag wheels which take that straight type with washers. And Hummer wheels take the same 60 degree seats, too. /forums/images/graemlins/wink.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    -Dan
    You are correct. AFAIK, there are only two types of lug nuts, 60* and mag type.
    9/16-18, I'll 3rd or 4th that one.
  14. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Dually GMs have a different pitch, dont know what it is but its much more shallow.
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Some of the dually nuts I've seen were shaped like a flanged nut. Can't explain it, but just looks like the nut with the washer, you know? /forums/images/graemlins/thinking.gif
  16. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I use 9/16 X 18NF Autozone PN 98920 $1.19 each (stock open style)......believe it or not it took 3 tries for my local Autozone to come up with the right ones, so hopefully a PN will be faster for you /forums/images/graemlins/thumb.gif
  17. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    There is a 3rd style of lug it is a ball seat honda lug. Those weird little falnged lugs are a torque retention design for hub-centric wheels (a lot of dually's and new fords)
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well in that case, I forgot, some Mercades and Audi use BOLTS instead of nuts to retain their wheels. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, you should send Bill (45acp) or Sean (45acp,jr) a PM and ask about their stainless steel lug nuts. Granted you get what you pay for, but they will never rust! /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  20. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Also jusy a note some 1 ton axles may use left handed threads. Our 1 ton F350 uses right twist on one side and left twist on the other /forums/images/graemlins/dunno.gif
