1 ton master cilander (pushrod)
Discussion in 'The Garage' started by wraenking, Nov 14, 2006.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    since i failed inspection for the rear brakes not appkying enough (rear disc conversion) i installed a 1 ton master cilander to see if that would help. the rear discs are getting warm now, but im not sure if they are working enough.
    do i need to lengthen the push rod at all?
    thanks
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    If you mean the pushroom from the booster to the master, NO. Don't go fiddling with it or you WILL pop your master cylinder.
    Ask me how I know. :doah:
    If the rear isn't applying ENOUGH, you should be thinking about bleeding the brakes... rears usually apply too MUCH, thus the proportioning valve thing.
    Or reset your stock combo valve -- but you do that as part of the bleeding process, right?
    -- A
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    If it's a pick-up it may be the load sensing prop valve is mis-adjusted...
    If it doesn't have the load sensing prop valve I'd be looking at the standard prop/combo valve on the front crossmember. Usually if they're not 'centered' the brake light will be on though...but it could just be limiting flow to the rears.
    I run rear discs and can lock all 4 tires (39.5's) on dry pavement. Hydro boost, '83 C30 master, stock prop/combo valve, and D44 calipers in the rear.
    Rene
  4. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    put the rear up on jack stands and test your brakes, and the holding power by putting it in drive and see if the wheels stop. also try in 4 low( with hubs unlocked of course.
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ill try that this weeknd. thanks for the info.
