1 ton or 1/2 ton TREs for crossover
Discussion in 'The Garage' started by MudFlap, Apr 15, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I have searched and read for about an hour and a half and I am really confused.
    What is the difference between the tapers on the 1 ton and 1/2 ton ends? I have read where there is nothing different, then I read where the tapers are different, then I read where the taper is the same it is just longer on the 1 ton ends.
    Does the superlift pitman arm # 1104 come tapered to fit 1 ton TREs or 1/2 ton TREs?
    Which is better to use if there is a difference between the ends? I would assume that 1 ton ends would be bigger. But is it really necessary to use 1 ton ends or will 1/2 ton ends work just fine?
    TRey
  2. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    anybody?
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have that pitman arm and I use the ES2234R and ES2010L tie rod ends. Those seem to be what everyone uses.
    HTH.
    -- Mike
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i been trying to find this same answer,
    are those half or one ton?
    i want to use my half ton Draglink ends, for the simple fact that i got 2 sets of spares,
    Will my 1/2 TON Draglink ends that were used on my stock steering, work with the Superlift drop pitman arm?
  5. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks.
    Does anybody know what the difference is between the 1 ton and 1/2 ton TREs.
    Trey
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the draglink ends are the same for 1/2t and 1t, so the moniker is again incorrect
    the question is "are you gonna use the draglink ends or the tierod ends?"
    draglink ends(es2026 and es2027) have a larger taper and have greater capability for misalignment
  7. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I am gonna use TREs, but I am trying to decide between 1 ton or 1/2 ton TREs. Does anybody know what is different about the tapers of 1 ton and 1/2 ton TREs?
    Trey
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    try posting pn for the ones you want to use.
    I have yet to see anyone use a pair of chev TRE, usually the short chev paired with another short ap
    es2234r es2010L
  9. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Somebody please correct me if I am wrong.
    es2234r is a TRE from a 1/2 ton truck
    es2010r is a TRE from a 3/4 ton dodge truck but it is used because it does not have the hole in it for the steering stabilizer thus making it stronger.
    The steering arms that I have looked at buying are either tapered for "large gm tie rod ends" or "1 ton chevy ends".
    I would run the es2234R and the es2010L ends, but I don't want to buy a steering arm and it be tapered for the wrong end. That is why I want to know what the difference between the 1 ton and 1/2 ton TRE tapers is.
    Trey
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dunno but all this crap is getting pretty confusing, i just bought a superlift drop pitman arm for a 78-79 chev, and i tried 1/2ton gm TRE, 1ton gm TRE, and DRE from my blazer and none of them look like they are going to fit that well, i think you are gonna have to have some tapering done no matter what, but i maybe wrong, hopefully.
  11. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I think that you are supposed to use the superlift dropped pitman arm for a ford, part # 1104.
    Trey
  12. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    tahts the one i got,
  13. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I thought that the 1/2 ton gm tre's were supposed to fit.
    If you tried both 1/2 ton TREs and 1 ton TREs then you should know the difference between the two tapers. So what is the difference?
    Trey
  14. chevyman_400
    chevyman_400 Registered Member
    Dec 16, 2002
    74
    Billings Mt
    the size of the stud it self is smaller on the half ton. I tried to put some on my d.60 and I never was able to get the taper to "set" as soon as I got The one ton ends the taper set and would not pop loose
  15. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i didnt look real hard, but the half ton TRE's are noticably smaller then the One ton TRE's so you must be right, but it seemed like the Halfton TRE's would almost be too loose, i never put a nut on any of the ends when i was looking at them with the pitman, but i think you are right about the half ton TRE's fitting, im just gonna get the Arms taperd to accomadate a bigger end, those 1/2 tons look puny
  16. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I have a stock replacement tre for 1/2 ton draglink, I bought it and cant return it, if you can use it I will sell it for 1/2 of the new price, let me know? /forums/images/graemlins/ears.gif
  17. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Trey, I have asked for this information also and got the same mixed answers and still did not know for sure. I just took my Superlift arm #1104 and mated it to a es2234r TRE and also a es2010r TRE and they are both a mate to the correct taper. I then measured the taper of both TRE's on a comparator and calculated the sine of the angle and multiplied by 12" to get the taper per foot. The correct taper is 1.5" per foot for these TRE's. I do not have the larger TRE's that you talk about so I can not measure them but if they have a larger taper then they probably are 2" per foot. That is just a guess.
  18. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks,
    Does anyone else have any more advice?
    Trey
  19. supersize75
    Sep 27, 2002
    2,638
    ttt on this one /forums/images/graemlins/thumb.gif
  20. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I used the sky steering arm and the superlift pitman arm and 1 Ton TREs and everything has worked great so far.
    Trey
