1 TON OR 3/4 TON BRAKES
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, May 22, 2003.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    ok got my 14 bff and my d60 between the both of them it cost me 400.00 so i have alot of extra cash to spend . i did the a tron conversion to the 14b and would like to change the brake set up on the dana 60to 3/4 ton rotors and calipers. so my question is do any of you guys know where i can buy a caliper bracket to do this conversion ? or should i leave it with the stock set up ? PS I STILL NEED LOCKERS AND GEARS
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Why downgrade to 3/4-ton brakes on a D60? /forums/images/graemlins/confused.gif
    The thinner 1.25" thick rotors that Ford/Dodge use on their 1-tons have problems with warping & cracking.
    Can't hurt to have stronger front brakes than rears... about 70% of your braking comes from the front anyways.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    3/4 ton dana 44 axles are best place to get rear disc brake conversion parts, caliper bracket, rotors, and calipers
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I agree with U2slow, don't do it. The bigger brakes are much better for our application when you consider the oversize tires. At worst, grind them to fit a 15" rim.
    If you must convert though, take a look at Wagoner Machine Shop's web site. They have a kit but it's $550. /forums/images/graemlins/eek.gif
  5. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    You WANT bigger brakes on the front! Why do you want to change? If you need brake clearance go with recentered hummer beadlocks, then you will have beadlocks AND good brakes.
