1 ton parts!
Discussion in 'The Garage' started by Wally81k5, Sep 25, 2002.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    Tell me this guys, how come people don't find a new way to make our k5's 1 tons? If the dana 60 is so expensive. I was wondering about putting some (hate to say it) ford axles under my k5. I know there would be a lot of work getting them to stay under there, but they may be more affordable. Is there anything i should know before i get to involved infinding an awnser to this? Please let me know folks. Thanks
  2. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    There's a F*RD high pinion D60 that many of us would love to have, but the pumpkin's on the wrong side which means you also need a F*RD NP205.
    The Dodge D60's are reportedly ALMOST a bolt-in...spring perches are within about 1/4" of what we'd want.
    Sorry to say it....costs aren't going to be much better. If you are still interested in pursuing this, do a few "keyword searches" in the '73-'91 Forum, and The Garage....This question has been asked about a hundred times, so there should be lots of info already around. /forums/images/icons/grin.gif
  3. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    yeah, the ford 60's are just as expensive.
    just be patient and look around. You will find a good deal on a GM one and it will be less work.
  4. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I'm contemplating doing this swap, since I have a HP Ford D60, an NV4500, and a GM NP241HD that has a SYE and the drivers side drop. The spring perches on the HP D60 are the same as the GM (31.5"), so all I really have to sort out would be steering issues, and possibly oil filter/driveshaft clearance (thanks mj!), but that is not much of an issue, IMO.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I doubt the oil filter would be a problem, it doesn't really come down any lower than the bellhousing, and the bellhousing is even closer to the highend of the driveshaft. You should be golden as far as the clearance issues go. Sounds like a cool swap /forums/images/icons/cool.gif </font color>
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    True, didn't think about that. I'm sure I will run across OTHER stuff that does not fit...that's the name of the game! /forums/images/icons/wink.gif
  7. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Throw some rockwells under it. /forums/images/icons/cool.gif Cheap and different, if you do the work yourself. /forums/images/icons/tongue.gif
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    There not that much, I just bought a D60/14bff combo for $650.....I've seen people spend that much for 1/2 ton axles!! /forums/images/icons/wink.gif
  9. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Hope they don't burn your truck down.
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just saw a Complete K30 w/454 in the paper for $800.......I didn't get to it in time.....there are some good prices out here....... /forums/images/icons/smirk.gif
  11. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Sounds like I need to go to Ohio. /forums/images/icons/smirk.gif
  12. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I just need to jack some farmer for his K30. I see at least 2 a day, just putting around, and the farmers don't know/don't care about their 454/400/205/60/14 combo. All they know is 'ah can't go faster'n about 55, and the damn big block sucks a lot o gas!'
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Wanna switch Cribs for a month next summer.....
    I gotta 61" Big Screen TV.... /forums/images/icons/grin.gif
  14. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Heard that! Problem is, most of the farmers in N. Texas use the trucks until the wheels fall off, them booger weld them back on for another round. Most of these trucks are beyond repair when they are retired.
  15. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    That's right...drive it into the ground, then leave it there.
  16. hungryjpr
    hungryjpr Registered Member
    Oct 8, 2001
    21
    SoCal
    Another difference between Furd &amp; Chevy D60's is the knuckles. Chevy's are (usually?) the kingpin style. Not sure which is really a stronger setup though.
    Matt B
  17. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    The '78-'79 Fords are the ones w/ the right spring perch width and they also have kingpins. The newer Fords have a wider frame and balljoints. The new Fords (S/D) have a unitized hub as well as the balljoint/wide frame.
  18. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    If filter clearance is an issue, run a remote oil filter.
  19. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    That is what I intended to do, but I think Shaggy is right about the bellhousing vs. the oil filter.
