1 ton PU
Discussion in 'The Garage' started by AZ79K5Project, Mar 19, 2006.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Guy is asking $1000.
    1979 1 ton P/U 4x4 longbed 411 gears - not a dually:
    Is this a K30?
    What axles did this come with?
    Guy says 10 bolt and 14BFF. (Shouldn't this be a D60?)
    Is this a good donor truck for axles, etc?
    I have a 79 Blazer 10/12 bolts.
  2. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    It should have a dana-60 up front, and a 14-bolt in the rear. Make sure the truck is what the guy says it is. He might be trying to tell you what you want to hear, just to sell it to you...$1000 for this truck, if it has all the 1-ton running gear is a decent price.
  3. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I think d60 have ten bolt covers so you might want to check
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Yep, D60s do have 10 bolts on the covers. Some guys have gotten wicked deals cause of that little detail :)
    Check to make sure that it has 5 gallon bucket sized hubs (not quite, but you know, lol) and only 3 u-bolts :)
    If it does, wave 800 bucks cash infront of him, and he'd probally let ya take it right there :)
  5. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
    Also make sure it is a D60 because someone may of already pulled the 60 and put a 10 bolt in its place.
  6. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    or a 44
    theres alot of axles with 10 bolts on them.
    if its not a round cover axle(10 bolt gm) thne check the corner of the diff housing webbing for a 44, or a 60, big raised numbers, wipe, scrape it off real quick
    79 could be any of three different axles
    10, 44, 60
    depending on whether its a 20 or a 30 series
    after 79 its either a 10 or a 60, from factory
    good luck
  7. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    Carfeull
    be very carefull if you cant tell by looking at it do not buy until its confirmed! i cant tell you how many (1 ton ) trucks ive gone to look at for the same thousand dollar price tag that were really 3/4 tons . some even had the 1 ton emblems . so even if you have to get really dirty to check it out its worth it when you see what your actually getting a killer deal or ripped off so take your time:D
  8. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Look for king pins vs ball jounts on the front.
  9. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    One more question
    Opinion question from the builders: If I found that someone already harvested the D60 and it has a 10 bolt 411's and the 14ff 411's, would it still be worth it for the gearing change? :confused:
    I have I think 308's or close to it based on the driveline spin test I did yesturday. (A little over three turns on the driveshaft to one turn on the front axle)
    I am running 33's and its doggy. Would the 411's make that much difference with 33's or bigger or should I keep looking for the next deal to come along?:confused:
    Swap the axles, 8 bolt wheels for the 6 I have and resell? What do you think?:confused:
  10. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    The gearing would make a huge difference from the 3.07 you got now. If thats what you want, then consider the gear changes alone hired done would cost that much. But it does seem high for just 3/4 ton axles. Any other good parts, engine, trans, t/c ?
  11. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    here is a sriped 60 front. not the king pins not ball joints and the bolts holding the plates on the diff side. this is were the 1 ubolt will be. and this is a pic of a complet king pin. first 2 years was cast cover rest are tin.
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    need to be careful though, if someone robbed the 60, and put in a 10/44, there is no guarantee that the ratios match.
