1 ton SFA S10 Build
Discussion in 'The Garage' started by ProJunkRacing, Oct 5, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Ok So this week I started to tear apart my s10 , and get everything ready for doing an SFA on it The Specs are a follows
    1991 2 Door S10 Blazer 4x4 4.3L (High Output) 700R4 , 231 . It has 35K on the highout put motor that the PO had built for it .$300 Paid For it.
    My Plans are as follows:
    Sky's Offroad Front 2" Lift SFA Swap hanger , Sky Shackle mounts, and their 6" Chevy Spring shackles , and I have 6" TC EZ rides from my last truck , that are going on this as well .
    I am using a Ford High Pinion Dana 60 that will have 4.88's , and an open diff , with crossover steering .
    As Far as the rear goes it has a 3 spring pack ,52" spring setup in it currently , so i am going to move the shackle mount to the bottom of the frame ,and put the shackles there since where it is now it is kinda pointless.
    In the Rear I am using a GM Corp 14 Bolt FF with 4.88's a Lincoln Locker , and Rear Disk Setup.
    From What I see so far I am expecting about 10" of lift so I would like to run 37" Irok's on Hummer H2 Wheel's is the plan , and that is all I am doing this year , next year maybe an atlas or something .
    Here are pictures of when I bought it and how it is now .
    All is gone but the IFS Front diff , and theo mounts that need to be torched off.
  2. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    It looks god bro. i have always wanted to build a s series with full size axles under it..
  3. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    I had a full size , and scrapped it but I did like the beefy Drivetrain lol .
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why are you so worried about cutting the fenders? it looks like they're junk anyways. :confused:
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    not that I am worried just that I dont want to . If I have to I have , but not going to be the first thing done per say.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you are going to need new driveshafts. if you go atlas later, your going to need new shafts again....just do the atlas now ;)
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    This is the type of thinking that will make a project snowball... I think this way and this is why i dont wheel. You can get shafts reworked... It may cost more in the long run but thats alot more wheeling you can do in the time being.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    exactly
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i know, im just giving him a hard time:D he is planning to daily drive it i believe. plus doing everything at one time ends the project quickly and then you have nothing left to do...what fun is that. but then again nothing is ever done.
    that rig should be fine with the stock 231, whats the low on that? 2.72 like the 241?
  10. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might want to look into a rear shaft from a 4 door s-10, they are just a little bit longer and that might save you the cost of having yors re tubed, i think i have a few laying around
  11. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Man Thats gonna be sweet when its done. Its going to be alot easier to fit that down the trails at badlands lol
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    SRW hubs would've helped immensely on the old truck. :rolleyes:
