1 Ton Shackle Flip
Discussion in 'OffRoad Design' started by Swanson52, Aug 10, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I've read that these differ from the 1/2 and 3/4 ton flips. What is the difference, and is it such that the individual flips cannot be swapped from side to side to utilize a longer rear leaf? Thanks.
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    The one ton has the springs closer together. The "one ton" brackets are narrower than the 1/2 & 3/4 ton brackets.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Just what he said. Spring perches are narrow on a 1-ton so we build the flip different to fit. You can still turn them around and/or move them fore and aft to suit what you want.
  4. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    so if i were to put one ton axles under my blazer i would need the one ton flip or the other flip?
  5. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    True one ton axles have the spring perches closer together than 3/4 ton axles. You would therefore need to get the one ton shackle flip and one ton front spring hanger. Or you would need to move the spring perches out somewhat to line up with the stock hangers and shackle mounts.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    converting the truck to use the 1-ton spring mounts would work but most of our customers just move the spring perches on the axle and use the flip kit to match the TRUCK, not the axle. So for a K5 you would use #GU38010. Not the 1-ton flip.
