1 ton springs on 3/4 ton Sub.
Discussion in 'The Garage' started by bigbluesuburban, Mar 13, 2006.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I want to put 1 ton springs under my .75 ton Sub...
    My Sub is an '89
    The springs are off of an 89 Crew Cab
    I need to know if there is going to be any welding or modification that I am going to need to do to make them fit.
    I am installing a 1" body lift and 1" zero rate springs front and rear from Off Road Design this upcoming weekend and I want to do the 1 tons at the same time. I need this to be a down and dirt upgrade so I can mount up my 33's and go cruise around the dunes the next weekend for a beach cleanup.
    Thanks for all the help.
    Lee
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If its just the spring and the springs your are using are the same length as the 3/4ton springs, then its a direct swap :thumb:
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I put 3/4T into a 1/2T burb does that count? They be a little stiffer but they will work
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I always thought the 1 ton springs were wider but all the spring company's list the springs as fitting 1/2, 3/4, and 1 ton so go figure.
