1 ton tie rod ends
Discussion in 'The Garage' started by berg76, Jul 22, 2004.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Im gonna be getting the new Sky Manufacturing crossover and hysteer arms that are one piece raised. Are 1 ton TREs the same as the 7/8s TREs that my blazer has stock?? When I search for an '85 K30 TREs on autozone.com it lists ones that will fit my blazer's centerlink/tie rod. 2027l and 2026r are the ones used on my centerlink. Is 2011r the big one?
    Also what size TRE is used with the 1104 pitman arm??
    Thanks!
    Cant wait to cross it up!!! /forums/images/graemlins/peace.gif
    ~jason
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know the thread on the 1 ton is 1" and on the 1/2 and 3/4 ton are 7/8". id like to know if the taper is the same?
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sky says there stuff is tapered for 1 ton TRE's but I am using 7/8" TREs without problems in my Sky steering arm. I am running #2234R TRE's at all my locations, and they are 3/4 ton stuff.
    I am using 7/8" TRE in my Ford #1104 arm too.
    Harley
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They are the same AFAIK. I have a dodge D60 and the 1/2-3/4 ton stuff works fine. It is also interchangeble with the 1 ton GM crew cab in my driveway. I think the 1" threads are the real difference. I have bent/crushed threads on the TRE's before shearing occured so that might be the reason for 1 ton stuff, but it was only when seriously abused.
