1 Ton U bolts
Discussion in 'Parts & Trucks Wanted' started by Batmanjr, Jul 23, 2002.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I need a set for the rear and the front D60! Cheap is good, haven't priced them locally though!
    /forums/images/icons/cool.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Rancho part number for the front kit is #738. Should cost around $40 for the kit. /forums/images/icons/wink.gif
    Don't have any numbers for the rear because of so many different lengths due to different heights of kits.
    Tell me what length of u-bolts in the rear you need and I can get you part numbers. /forums/images/icons/wink.gif
  3. Batmanjr
    Mar 23, 2001
    1,537
    I have a 4+1" in the front and stock in the rear! Thanks again Wess!
  4. ryanNC
    ryanNC 1/2 ton status
    Dec 7, 2000
    182
    North Carolina, Valdese
    OffRoadDesign sells them for 35 so you can run that 1inch block in the front if not they'll be to short!
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Superlift part number: #11364 will include 4 u-bolts (5/8" x 3 3/8" x 10"), 4 flat washers, 4 nylock nuts.
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Have custom bolts made, they are generally cheaper, and you can have them made to the length you need. When I did my D60, 14B conversion I had my 14B u-bolts 2" longer than needed so if the Jimmy didn't sit level I could add zero-rates and not have to change u-bolts. It didn't sit level, so I was able to add the zero-rates and not change the u-bolts.
