1 TONS AND 15" WHEELS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Dec 28, 2000.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    1 TONS AND 15\" WHEELS
    IVE GOT A 74 WITH A 14 BOLT REAR AND A DANA 44HD UP FRONT BOTH 8 LUG.QUESTION IS CAN I USE 15 " WHEELS WITH THIS COMBO,AND IF SO DO I NEED A SPECIAL OFFSET FOR THEM TO FIT?I DONT WANT TO RUN 16.5'S BECAUSE OF THE LACK OF A BEAD.ALSO 16" TIRES ARE EXPENSIVE AND A LITTLE MORE RARE THAN 15'S AND 16.5'S.ALSO CAN I STILL USE 15" RIMS ONCE I UPGRADE TO A DANA 60?THANKS FOR THE HELP.
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Re: 1 TONS AND 15\" WHEELS
    Well, I just swapped in a 14 bolt rear and swapped on 3/4 ton brakes and hubs to my front. The rear 15" wheels cleared the drums, but the front wasn't close. It would have been at least a 1/4" of grinding, way more than is safe. I imagine that a Dana 60 front has even bigger brakes, so I can't see it being possible without large spacers being used to set the wheel way outboard (not very nice to your axle). The only way to know is to try a set on for size! Good Luck... I had to switch to 16.5s, and I will probably put some beadlocks on in the future...
  3. mudddog91
    Dec 28, 2000
    471
    north carolina
    WELL I GUESS ITS 16.5'S FOR ME!OH WELL,HEY HAVE ANY OF YOU HAD EXPERIENCE WITH A LINCOLN LOCKER UP FRONT?WILL MY AXLE SURVIVE OR AM I PIPE DREAMING?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I have 15" wheels on my 14 ff rear and 8 lug dana 44 front. It took a little grinding in the front, theres still plenty of metal left. To fit 15s on a Dana 60, you need wheels with 3" backspacing and you need to grind the calipers. Those calipers are huge so I wouldnt worry about weakening them by grinding. I have seen it a lot in the magazines. What kind of wheeling do you plan on? Lincoln lockers would only be good for rockcrawling or side-by-side mud racing. The only diff I would put in the front is an ARB. Its expensive, which is why my front is open, but its there when you need it and not when you dont</font color=blue>
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Can 15's fit on a 1 ton 14b rear? I hear the drums are bigger than the 3/4 ton.
    BLAZER FOOD!!
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>When I brought my 1 ton 14 bolt home, it had drums on it. I switched to disks before I put it on, but I test-fitted a spare rim before to see if it would work. The rim was 15x10 with 4" backspacing and it fit over the drum fine. </font color=blue>
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Hey I like your picture SAVAGE1.
    90K5
  8. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    I bought some 8 lug 15 at a meet and did the same grind.
    Also have the same set up 14 with 44 up front.
    Will just barely fit.
  9. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I've put 15 X 10's on the following:
    3/4 ton Dana 44 Chevy front
    3/4 ton 10 Bolt Chevy front
    --required some grinding
    3/4 ton 14 Bolt FF rear
    1 ton 14 Bolt FF rear
    --fit fine
    3/4 ton 14 Bolt FF rear w/custom disk brakes
    --required minor grinding
    1 ton Dana 60 Chevy front
    --required LOTS of grinding, but when done there was still more metal left than a 3/4 ton starts with
    The wheels used were 15 X 10 JJ, standard offset, American Racing White Spokes and Mods made by Tech (I've heard these are no longer made).
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
