1" zero rate add a leafs in front?
Discussion in 'The Garage' started by fordslayer383, Mar 17, 2005.
    i was thinkin of gettin some of the 1" add a leafs for the front to level the truck up a bit.
    is this ok? ive heard of adding em in the back does anyone use em in front?
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I believe quite a few people do from what I remember, ORD recommends it and I will be running them in front soon so I'd think it's alright.
  2. cool man thanks! anyone got any pics of these installed
  3. bigcat44
    bigcat44 Registered Member
    Jan 29, 2005
    59
    Albuquerque
    I just installed mine in the rear last weekend and the instructions provided list for the front or the rear.
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Give me a day or too and I will post some pics of the ones on my 71.
  5. awesome
    i got a 2 inch body lift and i currently have 33" tires and i want to add the add a leafs to fit 315 75r 16's ????????? looks like theres plenty of room- and there definatly is in the back!!! i dont do to much rock crawin or anything so it flexes far enough for me!
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    i have them front/rear as we speak. No problems. They are coming out of the front soon, but just because I need clearance for my relocated tie rod, not because the zero rates have not worked or are unsafe.
    btw, if you want a set cheap, drop me a PM... I won't have any use for mine once I remove them.
    j
  7. which way does the rounded edge go? and does the pins sit in the recessed hole?
    i would be stoked on seein some instalation pics
  8. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    they are strait forward,
    the rounded edge goes tord the leaf to keep from making a pressure point. and the pin fits in the hole in the spring purch.
    done sent it.
    LUKE
    the resessed hole are for if you want to more your axle forward/backward, and the kit comes with extra bolts to make this happen.
  9. bigcat44
    Jan 29, 2005
    59
    Albuquerque
    Flat end is up against the leaf, bottom round end is resting on the axle side. Pin goes up through the beveled hole so it sits flush on the axle.
  10. for real? why the hell does it matter if one side is rounded then???
    gimmicks
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Actually the rounded side goes toward the spring. This is so when you're on the gas or brakes hard and the axle is trying to twist the spring, there aren't any large pressure spikes created in the spring pack. You only use the recessed holes if you are moving the axle forward or backward. I'm sure a search will turn up quite a bit more info on zero-rates as well.
  12. Grim-Reaper
    7,385
    Atlanta
    Rounded toward the spring so that it doesn't provide a shear edge to break the spring.
    What makes a Zero rate a Zero rate and not a block is the fact that its permanently attached to the spring with the center pin just like a leaf. It it slips out its because that pin has broken. Pins usually break from incorrect u-bolt torque.
  13. bigcat44
    Jan 29, 2005
    59
    Albuquerque
    when you buy them, they come with great install instructions. There are three holes, and it explains which hole you will use and why. The recessed hole goes down and the pin slides up through that and through your spring pack that way everything sits flush. I am not sure which side is the recessed hole I think it is the flat side and rounded side is towards the pack, sorry I am being too lazy to go outside and look. One thing I did that the instructions did not say was I kept my angled shims in place on the axle and put the blocks on them. Seemed very logical and have not had any problems.
