1" zero rates Front and Rear?
Discussion in 'The Garage' started by coptezr, Mar 26, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    Could i put them in the front also? would i have to change out any other parts?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Yes they are fine in front because they are part of the spring pack. I run them front and rear with no trouble.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Make sure your u-bolts will handle the extra inch in the spring pack. I have them on the front of my 71.
  4. coptezr
    Jan 13, 2005
    342
    now i have rear blocks will the zero rates still fit?
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    No,I wouldn't stack blocks. You would be asking for serious trouble IMO
  6. coptezr
    Jan 13, 2005
    342
    alright i was just wondering thanks:crazy:
  7. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    I always though is was ok to use zero rates with a lift block. The zero rate is bolted/attached directly to the spring pack.:confused:
  8. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    yes.
    the center pins and possibly the u-bolts... other than that, no.
    j
  9. coptezr
    Jan 13, 2005
    342
    so its ok to use them with blocks huh?:confused:
  10. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    it is ok to use with a block, they is absolutly no difference between using one with or without a block, it is bolted into the spring pack so it is 100% safe. it is not really stacking blocks.
  11. coptezr
    Jan 13, 2005
    342
    cool thanks i jsut dont wanna die:(
  12. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    as to the stacked block stuff. i wouldnt run one at all. more chance to pop a block out. the center pin is only for holding the leafs together and to center the pack on the pad. and just a nother idea to try is call or go to the state inspection shop and make sure it is legel in your state to do this. most states dont like this at all.
  13. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    i dont know anyone who has ever lost a block. you cant really loose a zero rate or a block if you torque the ubolts correctly.
  14. sweetk30
    Nov 1, 2004
    25,526
    526
    not saying it will happen just not a good idea. and buy the way i worked at a spring shop for about 1 year so that is where i get my info. but do as you like its your ride. just check the ruels and regulations of your state. that is all.
  15. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Running a zero rate with a block is no different that running a flipped overload spring with a block.
