10,000 Lb. Capacity Electric Winch With Automatic Brake And Roller Fairlead $300
Discussion in 'Pacific Region' started by kennyw, Apr 2, 2007.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Barely used winch. Still in excellent condition. Below is the text from the vendor website. They retail for $600 new. Asking $300 obo.
    10,000 LB. CAPACITY ELECTRIC WINCH WITH AUTOMATIC BRAKE AND ROLLER FAIRLEAD
    Planetary gearing for fast line speed and sure hold. Three stage system with automatic load-holding brake.
    * Power in/out
    * Remote hand control switch with 12 ft. cord
    * Automatic load-holding brake
    * Roller fairlead smoothly guides wire in and out of the winch
    * Line speed (in feet per minute): 6.56 FPM @ 2000 lbs., 6.23 FPM @ 4000 lbs., 4.92 FPM @ 6000 lbs., 4.26 FPM @ 8000 lbs., 3.28 FPM @ 10,000 lbs.
    12 volt, 4.8 HP, Drum diameter: 2.64'', Gear ratio: 294 :1, Cable size: 3/8'' x 100 ft.; Bolt pattern: 10'' x 4.5'', Overall dimensions: 21.9'' L x 6'' W x 6.8'' H, Weight: 84 lbs.
