10 12 14 bolts in the ring gear
Discussion in 'The Garage' started by CHEVY 4WD, Jan 26, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Some one told me the corprate axles were called 10(12 and 14) bolts because thats how many bolts hold on the ring gear I alway though it was how many bolts are in the diff cover whos right or is it both of us?
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Cover bolts. The C14 FF has 12 ring gear bolts and is still referred to as a 14 bolt due to the number of cover bolts.
    Rene
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Cover bolts are what I count. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Like the Canadian said,
    Cover bolts.
    10-bolt, 12-bolt, 14-bolt are all knuckle drager gear head talk for their real identitys, which would be the ring gear dia.
    It can be miss-leading tho', there are 4 different "10-bolts", 2 different "12-bolts" and 3 seprate "14-bolts".
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    could you explain that better for me?
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Ohh-tahay
    10-bolt:
    - Car/Truck - 7.5" Semi-Floater: Astros, S-10s, camaros and the like...
    - 1/2ton Truck - 8.5" Semi-Floater: '77-ish and up C/K series.
    - 1/2ton Truck - 8 5/8ths Semi-Floater: '99 and up Silverados/Savanas, (they are NOT the same as the earlier 10-bolts, but look very close.)
    - ?????? - I could have sworn there was a 4th 10-bolt, but I'm drawing a blank now...
    12-bolt
    - Car - 8.875" ring gear, Big-blocked and High-Perf Small-blocked early models. camaros, Chevells ect..
    - Truck - 8.875" ring, 1/2 ton chevys/GMC
    14-Bolt
    - Truck - 9.5" Semi-Floater: Heavy-halfs and up to light-one tons (8600 GVW), guesssing at '86 and up, but could be wrong.
    - Truck - 10.5" Full-Floater: This is THE axle, this monster has been used forever and is one stout assembly. Three bearing pinion (like the Ford 9) and and large ring gear make s all-most indistructible, rated up to 11,000 GVW (?). Single and dual wheel.
    - Truck - 11.5" Full floater: The axle assembly that is behind the Duramax/8.1L, this sucker is BIG! Really Big. Same shafts (more-or-less) as the 10.5s but a larger ring gear and a 2-bearing pinion.
    11.5" ~vs~ 10.5"
  7. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    *tips hat in Eric's direction* /forums/images/graemlins/thumb.gif
    Technically the 28 spline and 30 spline 10 bolts could considered as different...
    Also I heard a rumor there was an 8.6" 10 bolt out now under some of the new junk.../forums/images/graemlins/wink.gif
    Rene
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Well some of the new 10 bolts have larger carrier bearings and to my knowledge i dont know if they will work with the old style bearings and housings. /forums/images/graemlins/angryfire.gif
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Thanks for tha info anyways I already knew that stuff though I got one more questions for you though who make the EARLY 10 and 12 bolts? Spicer or AAM? I always though it was spicer but just wanting to check
