10-12BOLT
Discussion in 'The Garage' started by CHEVY 4WD, Sep 18, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    How much stronger is a 12 Bolt then 10 bolt? and how much more does it weight and how much more does a 14 bolt weigh then a 10 bolt
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> A 12 bolt is marginally stronger than a 10 bolt, but it's not anything to write home about. The weight difference is negligable too, I'd say it can't be much more than 30 lbs heavier, if that. The 14 bolt, on the other hand, must weigh twice what the 10 or 12 bolts weigh, at least with the drums on it. With discs it's still probably 150 or so lbs heavier. </font color>
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    What can 12 bolts be found in? Are they concidered 3/4's? and what the newest thing there in and did any of them ever have disk brakes?
  4. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    my neighbor works for GM as a repair rep or something and said the new H2's have a 12 bolt. Haven't seen it myself but he's probly reliable
  5. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I have two 1980 1/2 ton trucks with 12-bolt rears, factory. They are only considered 1/2ton, not 3/4. None had factory rear disc brakes. I believe GM went to 10-bolt rears in 1981-82. I ran 35" tires on a 12-bolt for quite awhile, with the factory limited slip, and never had a problem with it. However, I do intend to play harder, I just swapped in a 14-bolt rear.
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The 12 bolts are 1/2 ton axles, GM stopped making them in about '80 but they can be found in trucks as late as '82s. After that they were replaced with the 10 bolt. Newest thing they're in would be late 70s early 80s pickups, and none of them came with discs, although there are kits made to convert them.
    I really doubt that the H2 has a 12 bolt in it, since they haven't been made in over 20 years. I've got it on good authority that those H2s are actually based on a reguilar 1/2 ton truck, not the 3/4 ton as was originally reported by the media. I'm still waiting for pics from a real world H2, not a press model. </font color>
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    For the H2, based on the specs I have seen the rear axle is basically a 9.5" 14-bolt semi-floater.
    For the 10 to 12 bolt swap, I guess if you need a new rear axle and want an easy swap than it would be a good idea. Just as Shaggy stated, a 12-bolt is just slightly stronger than the 10-bolt. The 12 does seem to hold up okay for moderate useage.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Well seeing how 12's are harder to find Im wondering if its even worth it. 10bolts are all overthe place
