10.5 14B Pinnion thread size?
Discussion in 'The Garage' started by DukeBoy88, Apr 5, 2006.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Does anyone know the thread size for the pinnion nut on a 14BFF axle? My closest guess from measurement is 1" 16TPI. However I can't find a tap or die in this size, and I need to clean up my threads. I've checked Grainger, MSC, and McMaster Carr without luck. I've found 1" 14TPI but that doesn't seem to be the correct size. Is it metric? Any help on the sizing or source of the tap and die will be appreciated. Thanks in advance.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I know it takes a 1-5/16" socket
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    I can check mine and get back to you tomorrow. a 1 in UNC is 8 TPI, a 1 in UNF is 12 TPI, and a 1 in UNS is a 14 TPI. Im guessing it's probably a 14 TPI with out seeing yet. UNS denotes a "special" thread.
  4. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Thanks, good info.
  5. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    anyone know?
  6. rdn2blazer
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    it is 1-14 TPI.
