10 and 32 spline 205- do they both use same adaptor for sm465?
Discussion in 'The Garage' started by COCHEV, Sep 21, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i have the 32 spline version 465 with a 208 and am looking at going to a 205. i have a line on a 10 spline case and adaptor. could i convert the 205 to 32 spline and bolt it all up or are the output shafts on the 465 different lengths between the 2 spline counts? thanks,
    jason
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 19 and 32 spline 205- do they both use same adaptor for sm465?
    GM never used a 19 spline t-case of any sort. You must be looking at a Dodge case. GM only had 10, 27 and 32 spline cases. /forums/images/graemlins/thinking.gif
  3. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    oops, my bad. /forums/images/graemlins/tongue.gif i'll change the title. i ment 10 spline. /forums/images/graemlins/ignore.gif
    thanks wes
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The 10 spline NP205 uses a smaller bearing and different adapter than the 32 spline version.
    The adapter for the long 32 spline input for a sm465 has a round bolt pattern compared to the figure 8 bolt pattern of the 10 spline version.
    Not a direct or easy swap...
    But, I had done some looking and if you get the 10 spline version and the figure 8 adapter, then buy the short 32 spline bearing and input from ORD (TH400 parts) and machine the NP205 for the big bearing. You could then bolt up the figure 8 adapter between the SM465 and NP205 and the output shaft may need to be trimmed by 1/2-1".
    I have not done that yet but was looking at it very closely. Just didnt have the funds to test it out yet.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The GM long 32 spline adapter is what was used on my '86 K30's TH 400, correct? That means I can bolt that transfer case, with adapater to an '82 model year SM 465 and have a 32 spline setup for my truck?
  6. kennyw
    Jun 9, 2002
    13,223
    94
    No, SM465 and TH400 use different adapters. The long/short 32 spline inputs refers to the input shaft itself. TH400 use a short 32 spline input shaft and the '85 and up SM465 uses the long 32 spline input shaft. You might want to take a look at the ORD website if you want to see a side by side comparison.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can use your '86 case and bolt it to an '82, or even '81, BUT you will need to use the '85-'91 adaptor meant for the 465/205. Your 400/205 adaptor won't work.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I take it those adapters are hard to come by?
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Eehhhhhhhhh....well.....not really. You just gotta know where and who to get ahold of.
    Put it this way: '85-'91 one ton 4x4's with the 465/205's were a lot more available in the parts category compared to the 465/203 combo which was produced for only one year. /forums/images/graemlins/thinking.gif
    About the only place you are gonna have the best luck is at the salvage yards, even if they are asking $200, give or take, you better snatch it because they are no longer made from GM new anymore.
    As luck would have it, I've got this adaptor, but unfortunately, I dropped it and broke the 465 side of it near the bottom. /forums/images/graemlins/tongue.gif /forums/images/graemlins/angryfire.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nevermind then screw that. I'll keep a 10 spline box before I'll put a 208 back in my truck simply because the adapter is unavailable.
