10 and dana 44 parts swappability???
Discussion in 'The Garage' started by Supreme70, Jan 1, 2006.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    which parts of a 10 bolt front will fit a dana 44 front exactly, the 10 bolt is a 87 and the dana is a 77. I want all piece's that will go from one to the other.
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Knuckles,spindles,stub shafts,brakes,hubs. everthing from the "c's" out but not the iner axles. The 76' and older 44 knuckels had flat tops and can be machined for cross over steering, food for thought. Also if you have 4'' or taller lift springs the 10 bolt tie rod bar can be used on the 44 knuckels to gain about 3''s of tie rod clearence.;)
