10 blt strength
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NYC K5, Apr 22, 2000.
  1. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    ive doubbled my blazers hp since ive got it a year ago, its still the stock height with 31" bfg and the stock 10 blt front and rear axles, what will break on these and when, under extreme off road or spinning the tires on the pavement. how can i make them stronger or should i go with 12 or 14 blt axles
  2. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    10 Bolt's suck.
    10 BOLTS O' FUN
  3. Truckfan3
    Truckfan3 Registered Member
    Apr 22, 2000
    6
    Northern IL
    I blew my 10 bolt (and trans) by rocking thruogh the gears... it was my first time stuck and I was up to the doors in snow. The carrier (differential) for the ring will crack in half and it will fall out when the diff cover is taken off. Go with a 14 bolt or Dana 60.
    If it isn't broke, then soop it up!!
