10 Bolt 14bff Swap E Break Prob
Discussion in 'The Garage' started by imaginepro, Jun 10, 2004.
  1. imaginepro
    imaginepro Registered Member
    Jun 8, 2004
    28
    St. George, Utah
    I just Swaped out my Junky 10 Bolt out of my 86 Blazer and put the much bigger 14BFF in it. The 14 Bolt came out of a 76 Pick up. Well Evey thing went fine. the only problem I have run into is that My E Brake Cables Are different. On the 14 Bolt there are cables comming out of both drums and look like they are ment to hook to some cables on each side of the Frame. Well my blazer, and with the old 10 Bolt there are 2 cables that come from the drivers side and go into the drums. The cable just crossed over the axle. So can some one help me or give me some Ideas. Thanks
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Get the newer backing plates for the 14FF is one way. 14SF plates are the same as 3/4-ton 14FF plates.
    Somebody on here had a sneaky workaround... not sure who it was though. Hopefully they will chime in. /forums/images/graemlins/thinking.gif
  3. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    Do you plan on getting disk brakes?
  4. imaginepro
    Jun 8, 2004
    28
    St. George, Utah
    No not right now but down the road and then that is a hole new ball game. fro right now i am going to stick with
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Check this out.
    Old Thread /forums/images/graemlins/thumb.gif
    By the way, where are you in UT?
  6. imaginepro
    Jun 8, 2004
    28
    St. George, Utah
    I am located in southern utah St. George Where are you?
    Thanks every one I'm just going to make it work the help was awsome happy wellin. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/weld.gif
  7. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Im doin the same swap right now. what i did is i removed the bolt in cables from the 14bff.I then cut the cables and removed the metel piece that bolts on to the backing plate.so now i have the piece that will bolt on to the backing plate, i drill out the small hole the cable goes through to 1/2 in. so now i slide the original 10 bolt cable through this piece and then bolt it to the 14bff back plate. And there you go,repeat the same thing for the other side and then just hook the cables up to the internal arm and you are done. ( except for some adjustment to the cable). I just ran into the same problem today and figured ths out real fast but it worked great. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    I'm up in Utah County but am movin to the midwest next week. /forums/images/graemlins/thinking.gif
