10 bolt 3.08 to 4.10's same carrier?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by little79k5, Sep 16, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    10 bolt 3.08 to 4.10\'s same carrier?
    i have 3.08's going to 4.10s any changes needed? do i need to get "thick" gears?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    Re: 10 bolt 3.08 to 4.10\'s same carrier?
    same carrier from 2.43? and up i believe
  3. dyeager535
    26,980
    Close, it was 2.73 and up /forums/images/icons/smile.gif
  4. little79k5
    Mar 27, 2002
    230
    panama city, fl
    cool. thanks
  5. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    why regear?
    did it a year or so back, and spent more for the regear than the cost of a good used 14 b with the 4.10's already in, and i still have 10 bolts
    $175 gears and install kit
    $400 labor for regear
    $575 sub total
    $150 new hardend axle shafts
    $ 75 new bearings and seals
    $ 75 new brake pads and wheel cylinders
    $375 new lockrites
    $1175 per axle and i still have 10 bolts
    very nice 10 bolts, but 10 bolts just the same.
    "if i knew then what i know now........."
