10 bolt 3/4 ton rear end...?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, May 26, 2003.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    i have an 81 k20 with 8 lugs and 10 bolts on the diff cover. i searched for this 10 bolt rear end for a 3/4 ton and i cannot find anything on it. even on the "axle identification chart" i cannot find it. can anyone help me? thanx.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    That's really odd. Your '81 K20 should have come with a 14 bolt FF from the factory. And, even if a 10 bolt was swapped in for some reason, they never came with 8 lug axleshafts. In short: I guess I don't really know the answer to your question /forums/images/graemlins/smirk.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/crazy.gif
    Wait, on second thought....I believe the Dana 60 rears have 10 bolts on the diff covers. Two questions for you: 1) are there big hubs coming out of the center of the wheels 2) is there a fill plug in the diff cover? If so, then I'm gonna say you have a Dana 60. I don't know why it's there, but I believe that's what it would be.
  3. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    yes, the big hubs are coming out of the center of the wheels. they have 8 bolts in them. again, yes...there is a fill plug in the diff cover. i dont knw if it makes a difference, but the cover is an after market chrome one. thanx
  4. heavy4x4
    Aug 28, 2002
    3,270
    Then it's a Dana 60. /forums/images/graemlins/thumb.gif
    Semi-floating "10 bolts" from GM don't have the big hubs.
    I'm guessing, unless GM ran short on 14 bolts, that someone swapped in that rearend from a Ford van or pickup, or even an earlier model GM truck (I think some came with dana 60 rears).
    I recently took a stroll through some junkyards around my area and I found LOADS of dana 60 rears...no good 14 bolts that I was looking for. /forums/images/graemlins/frown.gif
  5. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    so when i buy rims for this truck, do i have to get FORD 8 lug rims for the rear and chevy 8 lugs for the front?
  6. heavy4x4
    Aug 28, 2002
    3,270
    No, just get some 8 x 6.5" lug pattern wheels.
    The '99-up Ford Superdutys changed their 8 lug pattern to be on a 170mm circle (who knows why /forums/images/graemlins/crazy.gif).
    Also, there's something about the wheel openings being different sized, but if I remember correctly, I think it's the Chevys that have the biggest opening so maybe some dodge 8 lug rims won't fit over the Chevy hubs...I'm not sure. But, most wheels you'll find in the aftermarket will have the same size opening anyway.
  7. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    so is this dana 60 a full floater then?
  8. heavy4x4
    Aug 28, 2002
    3,270
    Yup /forums/images/graemlins/thumb.gif
  9. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    sweet. thanks for all the help heavy!
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes alot of dana 60 in gm trucks back since at least 63, very common under the 20 series trucks, most were 4.56 but a few were 3.54, most all dana 60 trucks before 73 were leaf spring but a few were coil rear(2wd)
    all dana 60 rears were FF cept a few 1/2 ton pickups and some dodge cars
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Maybe.
    The center hole size varies even with the same 8-on-6.5" pattern. I had a '72 3/4-ton with the factory Dana 60 rear. I tried replacing the split-rims with 80's GM 16" wheels and they would not fit. I had to borrow a couple of Ford wheels from a buddy. The difference was about 1/8".
    Aftermarket wheels normally use the largest avialable center-hole size to avoid fitment problems.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    and then you have the problem of weight of vehicle riding on wheel studs instead of on the hub center holes /forums/images/graemlins/mad.gif
  13. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Actually, GM uses the smallest center hole. GM trucks can use Ford and Dodge wheels, but Fords and Dodges typically can't use GM wheels. There are exceptions to all rules, but, for the most, part this is usually what you will find.
  14. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for clearing that up /forums/images/graemlins/thumb.gif I can never remember which way it is /forums/images/graemlins/tongue.gif
