10 bolt, 4:11 gears need shimming?
Discussion in 'The Garage' started by aj_tatted, Jan 13, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i need to re-shim the ring and pinion in my rearend. i've never done this and feel there's no time like the present to learn. can anyone tell me if there is anything special i need to know or tricks that might make it easier? any special tools i need? /forums/images/graemlins/thumb.gif
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    reshim?? was it done wrong?? There is a whole procedure for doing gears. A mag mount dial indicater will be needed. If you have to do a pinion gear, you would need a depth tool to do it right. What is the problem you are having??
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    5.13's
    the only reason i read this post was because i saw it was about gears and zakk was the last person to reply /forums/images/graemlins/rotfl.gif I must have ESP or something cause i knew what you typed
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's
    [/ QUOTE ] /forums/images/graemlins/thumb.gif
  6. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    well, when i put the truck in neutral and crawl under there to check the driveline, there's about 2 full inch's of play. Also when i'm cruisin down the road, when i let up on the skinny there is a horrible noise coming from the rear.
    I'm assuming the ring and pinion are slapping aginst each other.
    the only procedure i have heard of to fix this is to take it out and shim it tight. /forums/images/graemlins/confused.gif
    do you concure? /forums/images/graemlins/ears.gif
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you have a detroit diff in there? i've heard they have all kinds of slop in them.
  8. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    factory open carriers and some of the gov-locs will have alot of play in the spyder gears. Best to pull the cover off and check them. Usually gears don't need to be reshimmed. If they are loose, then something is wrong. If it's an open carrier, check the spyder gears and the shims behind them. They often break and cause extra play and noise.
  9. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    there is a detroit in there, what would that do?not sure i understand where your goin with that.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    5.13's
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I think, the bottom line is, your gonna have to pull the cover and see where your slack is.
