10 bolt, 4.56, detroit, discs, tires, wheels, tcase, etc....
Discussion in 'General Parts for Sale' started by K5Chris, Aug 16, 2004.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    custom sub box for 88-98 Chevy/GMC extended cab 2 AND 3 door trucks, and fits 2-10" subs..... $45
    NP241 passenger side drop Tcase w/ adapter to bolt right to 700r4 or 4L60. has bent output shaft. perfect if you want to install a slip yoke eliminator.... $250
    stock 10 bolt pinion yoke..... $10
    10 bolt rear differential cover....... $10
    *the stuff below is still on my truck..... I am upgrading my axles, wheels & tires..... so, this stuff will be for sale within the next month...... let me know if you are interested....
    (2 sets) 4.56 8.5" 10 bolt gears..... $75
    Auburn limited slip for 30 spline 8.5" 10 bolt...... $170
    disc brakes for semi floater axles with brand new pads, rebuilt Mustang SVO calipers ready for Ebrake, & resurfaced rotors..... $150
    2 sets of 30 spline 6-lug 10 bolt rear axle shafts......... $45 per pair
    10 bolt or Dana 44 6-lug hub/rotor a$$emblies: come with wheel studs, big bearing spindles, bearings, and caliper mounting plates (dust shields)........... $50
    4.56 THICK gears for 10.5" 14 bolt FF, brand spankin new in box...... $200 shipped
    spider & side gears for 10.5" ff 14 bolt....... $30
    complete 2.5" lift kit w/ 2.5" front springs, 2.5" rear blocks, and all u bolts.... $100
    2-Rancho RS9000's & 2- rancho es3000 (pro comp) for 2-3" lift..... $100
    half ton spring plates (good for U-bolt flip)........ $15
    stock 10 bolt steering arm...... $25
    4- 33x12.50-15 BFG A/T KO's with 50% tread......... $250
    4- 15x10 American Racing chrome modular 6-lug wheels....... $100
    1- 33x12.50-15 BFG M/T on matching 15x10 chrome mod (tire only good for spare) $40.... or free with purchase of tires & wheels above (all 5 still mounted & balanced for $350)
    *all prices do not include shipping
  2. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I might be interested in the gears if you get them removed soon enough
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    2.5" cast iron lift blocks with U-bolts......... $20
    Are these angled/tapered? Pic?
    Shipping to 46041?
  4. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    it will probably be about a month
  5. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    Shipping to 46041?
    no, they are not tapered, they are flat.
    i ship via fedex ground and they are very reasonable. probably somewhere between 4 and 8 bucks. i cant tell you exactly yet case they are still on the truck.
  6. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    where in texas are you?
  7. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    north side of Houston
  8. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    sent a pm
  9. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i forgot to mention, the np241 is out of a '91, so it has the electronic vehicle speed sensor, not the gear/cable setup. it does have a bent tailshaft, so it would need a new tailshaft or slip yoke eliminator kit. i have not run it, so no guarentees about it.... it might need a little reuild.
    i would rather not ship the larger heavier items like the axle assembly and the tcase. it looks like i'm going to part out the 10 bolt rear anyways.
  10. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
  11. 87_k5_silverado
    87_k5_silverado Registered Member
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    what would the shipping be on those 4 wheels be to 18235? Also what condition are they in; and when would they be ready for shipment? Thanks... /forums/images/graemlins/thumb.gif
  12. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    wheels are in very good shape. most of my new parts should be here within the next week.... so, probably 2-3 weeks.
  13. 87_k5_silverado
    Jul 23, 2004
    24
    Jim Thorpe, Pa
  14. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Any idea when these gears will be avail? Dont mean to rush but I am about ready to order.
  15. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i'm sorry, it will be another couple weeks. i keep changing my plans.
    i will have 2 sets of 4.56 10 bolt gears, and a 30 spline Auburn LSD.
  16. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    How well does the Auburn LSD work? How many miles are on it, and was it in front or rear? How much would you want for it shipped to 27217 (Burlington, NC)?
    Thanks!
    Richard
  17. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Ok if it's only going to be a few weeks I can wait, will you let me know if plans change. Thanks
    Adam
  18. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    Adam
    no problem..... i'm planning on going on a weekend offroad trip oct 8-11, so i have to get er done before then.
  19. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    Thanks!
    Richard
    the auburn is an aftermarket limited slip that uses clutches and 5 springs to transfer torque. it is VERY tight. the Auburn is one of the best, if not the best limited slip on the market. it is in my front axle, and gets very little use. i rebuilt it last year, and it's in great shape. it is 30 spline, so if you have a pre 89, you'll need to get some 30 spline shafts. i will have 2 sets of 30 spline 6 lug rear shafts for sale. i am looking to get $170 for the auburn. i would estimate shipping to be about $10-15, if it's more, i'll cover the rest. and, i want $45 for each pair of rear shafts, no idea on how much to ship those.
    http://www.auburngear.com/aftermarket/products/differentials/
  20. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Adam
    Great then put me down for both sets.
