10 bolt, 8 lug front axle torque specs (spindle)
Discussion in 'The Garage' started by Quack_Addict, Jan 2, 2004.
  1. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    After tearing apart my garage last night looking for my old Chevy service manual and finding every other automotive related book I own BUT the one I was looking for, I gave up.
    I need some torque specs for a GM 10 bolt front axle of the 8 lug variety. More specific, I need...
    * spindle flange nut torque spec (6 nuts on the spindle flange)
    * Spindle nuts (inner & outer)
    Thanks!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    45 ft lbs
    Inner 35 ft lbs
    Outer 50 ft lbs
    (Back nut off to align cotter pin at nearest slot)
    /forums/images/graemlins/thumb.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sorry man, but the D44 and 10 bolt front outer nuts are to be torqued to 150 ft. lbs., not 50 ft. lbs.
    Actually, the sequence that I've read, seen and used goes like this:
    1. torque inner nut to 50 ft. lbs. while spinning the bearing hub to seat the bearings.
    2. back off the inner nut and retorque to 35 ft. lbs., again, while spinning the bearing hub.
    3. back off inner nut 3/8's of a turn.
    4. install washer.
    5. install outer nut and torque to 150 ft. lbs. while spinning bearing hub.
    Thats how my GM service manual calls for the task. /forums/images/graemlins/thinking.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/blush.gif My bad
