10 Bolt about to blow! UPDATED!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, May 28, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    My rear 10 is about to blow! (sounds like I am running boggers when accelerating) I really dont care 'cause I have my 14 bolt waiting. The problem is I slated everything for later this summer for the swaps. How much can I run this axle howling. Whats going to happen when it blows? I have been fevershly trying to get my other truck back together so I have a ride still (looks like later this week) Thanks All!
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: 10 Bolt about to blow!
    A friend of mines blew. He didn't even now it was going out. He stopped at police station to get a deer signed off. And went out to start it and it was totally locked up. He couldn't even move. He diconnect the drive line to drive it home in 4 wheel drive and no good. He had to have it towed........Dan
  3. Cavalry
    Oct 1, 2000
    978
    Since I still have slip yolks pullin' the rear shaft to get home is kinda out of the question. Hopefully it'll explode all over the place so I can get some nice pics...hehehe
    Luke
    84 K5
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    The 10 bolt in my 89 lasted about 2 weeks when the noise got that loud. Thats driving 40-50 miles a day 6 days a week.
  5. Cavalry
    Oct 1, 2000
    978
    This is todays update....Blew some teeth of the ring gear I think (jumps and bucks wildly when acc from a stop and clunks pretty loud around corners) I guess we will see how far she goes!
    Luke
    84 K5
  6. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    when mine was goin out i was jumpin on the freeway and i punched it....and it just started grinding..i just sliped it into 4x4 and drove it like that with the gears grinding..i figured it couldent hurt it any more than it already was
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  7. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    This sucks. Mine's about to go to I think. Right when the money's tightening down too...
    Ratch
    **Hmmm. Land or Mall? Land or Mall? Let's see. Lotsa SUV's around here... Let's build a mall.**
  8. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    There is a chance that it can lock up while driving, most likely snapping the driveshaft.....If you are unlucky the front u-joint will snap and act as a poll vault...mine did this in the woods...Was't so bad because it was on the dirt. Pavement may be another story........Just be careful, I'd hate to hear you messed up the rest of your driveline over it all.
    Mike
    You call that dirty!?
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mpascino has an excellent point here!!! This is NOT a good idea to try and 'hot rod' the truck until the rearend blows up!!! I did that once on my old 81 short bed truck. The nut on the pinion fell off and locked up the pinion inside the pumpkin. At the same time the nut fell off, the whole driveshaft fell out too. It was a slip joint shaft and when it fell out, I ran over it by accident and ruined it!!! Another part to buy after replacing the rearend!!! [​IMG] Not exactly cheap, but if I were you and the rear is getting worse, PARK IT, and get it fixed or swap a different axle in. DO NOT try to blow it up!!! [​IMG]
    When In Doubt, Whip It Out!
