10 bolt and 12 bolt axle shafts interchangable?
Discussion in 'The Garage' started by divorced, Mar 5, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are 10 bolt and 12 bolt axle shafts interchangable? Are they the same length from side to side? A friend of mine has an '84 K5 with a 10 bolt and needs a new shaft and we need to know what trucks we can get one from for when we go shopping.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    12 bolts have 30 spline shafts and 10 bolts (prior to 1989 or so) have 28 spline shafts so no it will not work in your case. A 12 bolt shaft will work in a 30 spline 10 bolt with a slight modification.
  3. divorced
    Jul 20, 2004
    5,115
    Thanks, Now it's time to go shopping!
