10 bolt axle shafts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Nov 14, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    On my "new to me" 3/4 ton axle, when I removed the axle shafts there was surface rust on the axle shaft and the inside of the tube the axle shafts goes in. I used my angle grinder and a wire wheel on the shaft but how do I remove the surface rust on the inside? Also when I reinstall the shaft do I need to put any kind of grease or anything on the shaft? On the part that goes in the diff, not the part where the hub is.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    To clean the inside of the tubes on my D60, I went and bought a ball/flex hone and a drill extension. Put the hone on the end of the extension, attach it to a drill and there you go! Works VERY well[​IMG] make sure you get the hone that fits snug in the tube.
