10 bolt axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kyrel69, Jan 7, 2002.
  1. kyrel69
    kyrel69 1/2 ton status
    Aug 27, 2001
    122
    columbus oh 43228
    Front 10 bolt, what years have the 28 splines and what years have the 30 spline? Can you just change out your spiders or side gears to switch between the 2 axles? Are they the same thickness (1.31 28 spline I have read)
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The best that I can tell is that the front 10-bolts switched to the 30-spline shafts in '89 and were used until '91 when all of the 1/2 ton rated trucks went to IFS. The 30-spline shafts are 1.31" while the 28-spline are 1.28".
    I don't think you can put the bigger 30-spline shafts into a 28-spline carrier because the 30-spline carriers were actually machined out at the journals to fit the bigger shaft. I would also guess that you could put 28-spline shafts into a 30-spline carrier if you changed the side gears.
