10 bolt axleshaft u-joint part #?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, May 9, 2002.
  1. dyeager535
    26,979
    Anyone happen to have a part number for the 10 bolt axle u-joints from either schucks or napa? Wanna make sure I don't show up and get the driveshaft u-joint!
    I bet its been posted before, but search yielded nothing.
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    IIRC the Spicer # is 297 ..
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I just did the 10 bolt on my 78 K10 (last week I did rear brakes as fronts were in excellent shape, balljoints, tie-rod ends, balljoints, axle u-joints, stabilizer, bearings and seals so I can double check to make sure the P/N is correct), but NAPA P/N (IIRC) is RL1325.
    That is for the HD non-greasable version
    I am not sure what the P/N for the greasable version. The non-greasable versions require a little more maintenance as far as interval changes, but I think they are stronger. Maybe yes, maybe no, but when I had the 10 bolt in the 80 I busted a few greasable ones (from NAPA), then a friend suggested the non-greasable version. Plowing, truck pulls, etc. they lasted until I swapped it out (about two years of abuse).
    P.S. I haven't stopped looking for the R&P
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Actually, the Spicer number is 5-297X
  5. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    I thought you were locked in as a misspelled PP.
  6. RedDwarf
    May 9, 2001
    816
    Well, now I'm not LOL
    I don't know who fixed it, but I am glad about it. after the initial disappointment upon the end of my streak /forums/images/icons/smile.gif
