10 bolt brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, Sep 12, 2001.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    Ive got an 81 chev 1/2 ton with a 12 bolt rear end and have to swapp it in because my blazers rear end is gone and was just wondering if the brakes from my 10 bolt will bolt onto the 12.
    Thanks for any help
  2. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    there are two different brake measurements on the 10 bolt shoes. The shoes are either 2" or 2 5/8" I think. Not for sure on that 2nd one. Also not for sure but I think the larger of the two drums are 11 3/4" and smaller is 11". Feel free to correct me if I'm wrong.Sorry I don't have the photogenic memory.
    Thanks,
    Greg Gayman
    Hawglet
    Stovie
    hawglet@excite.com
  3. dyeager535
    26,980
    The only way to likely tell if there will be a problem, is to compare the backing plates. The way they bolt to the axle flange, and the wheel cylinder to brake line connection.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
