10 bolt build up
Discussion in 'The Garage' started by CR, Mar 27, 2004.
  1. CR
    CR Registered Member
    Mar 20, 2004
    51
    Don't laugh /forums/images/graemlins/rolleyes.gif I have a 87 K5 that I am building up for mild off roading ( hunting, fishing ) with daily driver in mind. Tire size will be 33x10.5x15. I don't think I need to upgrade the axles,and want to know what can be done to put some beef in the 10 bolts? Gears will be 4.10's with a trachtech locker front and rear. I was leaning towards c-clip eliminators and 30 spline axles. /forums/images/graemlins/1zhelp.gif
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    30 splines are senseless unless you plan on getting 4340 shafts or something.
    I'd go with rear disc if you're worried about losing a tire.
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I don't know if anyone currently markets a 10 bolt c-clup eliminator kit, but that would be nice. I think that the 30 spline axles give very little if any strength increase and are not worth the trouble.
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i was advised not to use c clip elimators on a street driven vehicle. if you are going to upgrade the axleshafts, get some alloy ones from moser, 50 bucks more per axle and they dont neck down at the splines. i second upgrading to disc brakes to keep the tires on the truck. for the front i would just upgrade to the spicer 5-760x u joints.
  5. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    I wheeled with my 10 bolt for a good long time with 35x12.5x15s on it. i have several good tid bits for you
    1. go get longer studs. the old ones just pound out and press in the new ones. easy. I lost a wheel once do to them shearing off.
    2. Spider gears are the next weakest thing. Ive gone through three sets. this is actaully a good thing, keeps somthing bigger or more exspensive from breaking. Just be sure your magnet is strong, as the pinion sucks up shrapnel and bye bye axle.
    3. there is a never ending supply of 10 bolt parts. I recently had a guy offer to pay me to take 3 gm 10 bolt rears off his hands.
    For your set up i think your fine. I wheeled rather hard and hit all but the hardest moab trails with the 10bolt. The driver has a lot to do with how much breaks. wheel smarter not harder.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I wheeled my rear open 10B with 33x14.50 SSR's and 350HP pushing but I only did mud and some moderate pulling. I never broke anything except for rear driveshafts. A 33x10.50 tire that is an A/T or mild M/T is not going to put much more stress on everything than your stock 31's would...Especially if you run some aluminum rims. With alums and 33" A/T's I bet that combo wouldn't be any heavier than stock steel rallys and 31x10.50" A/T's. 4.10's will be about perfect in my opinion and as long as you use a decent locker I would highly doubt you will actually ever break anything WITH the stock shafts. Might be a different story with a steel rim though.... For the front I say run it stock and just fix and beef up later IF it breaks. I have managed to keep a front 4.10 10B alive without any breakage with superlight alums. and 35x16" boggers and it is completely stock.
    I would say gear them, lock the back, LS the front or leave it open and not worry about it. /forums/images/graemlins/waytogo.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Here is my advice if you are set on running 10 bolts.
    #1. Don't do the c-clip eliminators. They leak really bad on street vehicles from what I hear. They are for drag race only applications.
    #2. Replace the rear differential (govlock, open) with a full case limited slip or locker. Takes away a major weak point.
    #3. Disc brakes in the rear. Will keep the axle in if you break it hopefully.
    #4. Spare axleshafts front and rear. (Mosers would be nice for the back with your stockers as spares)
    #5. Good ujoints in your front axleshafts. (Spicer, Neapco,...)
    #6. Easy on the go pedal and drive smart.
    33's aren't a huge strain on the front 10 bolt as long as it is in good shape. I run 35's and a locker in my front 10 bolt and so far so good. I make sure I carry spare parts though since I am going to rock crawl it. I carry the following for my front axle. (inner and outer axleshafts ready to go, spindle, wheel bearings, spindle nuts, yoke, races, locking hub)
    Harley
  8. Storm Trooper
    Nov 24, 2000
    4,640
    1st- Welcome to CK5!
    Next, buy spare axles, keep the ones you have well lubed and just take care of them. I don't think you should sink a bunch of money it them because the more you go off-road and get into tough spots, the more you will just want to change the axles to something stronger. Hang around here....you'll see!
    I ran 38.5's on my 10's and never broke them but I still went one ton. You'll get tied of trying to be easy on them all the time. Oh, and maybe get a winch which will help get you through the tough stuff.
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You just joined on the 21st and no one had taken that username? That's amazing! /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    for the same cost as some bling shafts for the rear 10 bolt you could get a used 14 bolt. lol!
    sorry, couldnt resist. /forums/images/graemlins/wink.gif
    j
  11. CR
    Mar 20, 2004
    51
    Thanks for the replies. If one were gonna swap in a 14 bolt are you getting them from junk yards? How much on average? Aren't the shock mounts in the wrong place?
    What would you do about the front axle being a different lug pattern, convert the 6 lug to eight? /forums/images/graemlins/doah.gif I know I know, swap in a Dana 60. But I am trying to go cheap and it is only a daily driver used mildly off road.
    Sorry for all the questions.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Dollor for dollor, a 3/4 ton axle swap still makes sence to me. Granted you'll have to get 8 lug rims, but when you figure cost of regearing the stock axles, and still being weak as stock axles are, the 3/4 ton swap looks better and better. Only bad thing is how low the center of the 14 Bolt FF hangs. /forums/images/graemlins/deal.gif You can get the 3/4 ton axles (14 Bolt FF rear, D44/10 bolt front) from K20 pick ups. I bought mine off a private owner for a whole whooping $250.00 for the matched set.
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    If you get a 14BFF out of a 3/4 ton it will be a direct bolt in. As for the front...try to get the matching D44 or 10B because it will already have the same gears and be 8 lug. Swapping over from a 1/2 10B to a 3/4 10B is a DIRECT BOLT IN. Same goes for a D44 to D44. If you go D44 to 10B or visa versa you will need different brake lines. A 10B and D60 caliper share the same size brake line fitting.
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can use your 10 bolt calipers on a D44 or vice versa so you don't need new lines though.
    You will probably need a conversion ujoint to mate your stock driveshaft to the 1350 yoke on a 14bff though too. Unless you truck was originally equipped with a manual or you swapped to 1350.
    You also may have some ebrake issues with different year 14bffs. My 14bff is out of a 78ish and my ebrakes on my 85 won't work without being modified to work.
    You also might need to drop your transfer case some or add a shim to deal with the angle of your rear driveshaft too since the pinion on the 14bff will move forward about 1" or so from your 1/2 ton axle.
    Harley
