10 bolt caliper issue with rear disc conversion
Discussion in 'The Garage' started by yunit, May 11, 2002.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    just grind that tab off of the caliper...when i went 3/4 ton with my front my 10 bolt calipers would not clear the new backing plates without grinding off that tab, i wouldnt groove the bracket
    Later
  3. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    The bracket looks like 3/8 plate and that is waaay overkill (but is good here). Grind the bracket!
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Pete,
    What is your plan for an e brake?
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    No! Don't grind the bracket.....just grind the caliper!
    Why mess up a good bracket when if the caliper goes bad later, you can try the D44 caliper and it may clear the bracket with no problems. /forums/images/icons/wink.gif
    To me, it's easier to grind and mess up the caliper because they are cheaper than the brackets.
    If you mess up the bracket, you gotta pay more to get another one.
    If you mess up the caliper, you only have to drive to the local parts store and shell out about $20 for a new one. /forums/images/icons/wink.gif
  6. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    For the time being I will be e-brakeless, I am waiting for biggray to get his t-case e-brake and then I am going to buy his eldorado's.
  7. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    The caliper it is!
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    are those 1/2 ton or 3/4 ton 10B calipers? Whose brackets are those?
  9. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    They are 1/2 ton calipers and the brackets are from MISFIT.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    1/2 and 3/4 ton 10B calipers are the exact same thing.
    You can swap either to the other and they will work just fine. /forums/images/icons/wink.gif
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so then everytime he does a caliper replacement he has to break out the grinder?
    screw that, bracket surgery is my vote.
    the consumables should be unmodified
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Think about this:
    Would you rather spend more money on the brackets, IF you were to "accidentally" grind too much or damage one?
    OR,
    Would you rather spend the $15-$25 for a new rebuilt caliper?
    I think I will stand by my beliefs here. /forums/images/icons/wink.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    looks impossible to mess up a simple plate bracket
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    You never know. /forums/images/icons/wink.gif
    There's always a moron out there who can mess up just about anything. /forums/images/icons/laugh.gif
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yup
    they are called engineers
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    /forums/images/icons/tongue.gif
