10 bolt carnage!
Discussion in 'The Garage' started by jk3078, Jan 7, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    So, I let the kids drive the sub-buggy today. While trying to do a brakestand burnout my fourteen year old daughter did this! Like father like daughter! Sorry havin trouble with the pics. Okay, got pics scroll down.
  2. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    havent seen pix but i bet it was the spider gears. it took me twice to learn that big tires arent ment to do burn outs
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    nah, big tires do great burnouts, its those stupid 10b's that werent ment for burnouts ;)
  4. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Ok here you go. The driveline was from a burnout I did a couple weeks ago.
    The drivers side carrier bearing cap is lose do you think that could have caused part of this? Maybe its time for some Superior shafts or...
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i think its time for a 14b sf to keep it light and strong... that wasnt an axleshaft problem...:rolleyes:
  6. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Ok maybe brakestand/burnouts are a bad idea with 35'' swampers at 10 psi on a welded 10b. But its still FUN! I'm not sure the axles broke entirelly from torque the carrier bearing cap being lose put alot of extra stress on the shafts.
  7. dyeager535
    26,980
    It kind of looks like the pinion shaft lock pin broke at some point...you can see the pinion shaft milled "flats" and all the carriers I've dealt with, those flats are parallel to the tires.
  8. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    You mean the "spider gear roll pin"? Good eye, yes when I got this truck the spider gears and roll pin where bolth fraged. The bolt that holds the roll pin in place was broken so I torched the pin out, swapped in different spiders and pin, then welded the pin to the carrier. Hoaky, I know, and its going to be a pita as to get out.
  9. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    uhh undo the leafs and toss it in the trash, If it doesnt fit cut it in half with a sawzall, only takes a couple of mins.
