10 bolt carrier fr 4:56
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Jan 20, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    Do I need a special carrier to swap to 4:56 gears in ten bolt and are the front and rear carriers interchangeable?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    No specials needed, and yes they are interchangable.
    Have done both.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i went from 3.73-4.56 and had no carrier change.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, 14ff, (soon to be- dana 60, flatbed,and 39.5" TSL's)
  4. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    What did it cost to have them installed?
    1987 Blazer, 350, TH700R4, NP208, 3.42, Rancho 4", 33"
  5. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Depends on where you live. got mine done for 150r and 200f but he has upped his price to 275r and 325f so thats is why i am going to do the next ones myself. it all depends on what the going rate on labor is where you live
  6. Texan
    Texan 1/2 ton status
    153
    Leander, TX
    No special carrier if you get the right thickness gear for your carrier and If you swap front to rear or vise versa on the carriers you better be sure you're axle spline count is the same or you''ve wasted your time....
    <font color=orange>STEVE<font color=orange>[​IMG]
    67 Camaro 468
    68 CamaroSS 327
    89 K5 Blazer
    94 GMC K3500 Crew Cab 4x4
    98 Pontiac GTP
