10 bolt carrier question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88sub4x4, Oct 28, 2002.
  1. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I rebuilt my blown 10 bolt rear axle about a year ago. I put in an Eaton limited slip carrier as my old one was cracked. My current ratio is 2.42 I am putting a 14 SF in the rear with a 4.10 ratio. My question is can I put the limited slip carrier from the 10 bolt rear diff. in the 10 bolt front diff. with a 4.10 ring and pinion? I have heard that the carrier would be too small. The current ring gear is 8.5" i believe. Any help is appreciated. /forums/images/graemlins/burb.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Don't see why you couldn't, but you'll need the thick style 4.10s to fit on that carrier. </font color>
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    No go. If I'm not mistaken, a 14bsf has a 9.50 ring gear.
    Jim
    /forums/images/graemlins/usaflag.gif
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think he's asking about taking a carrier from a rear 10 bolt and putting it in a front 10 bolt. </font color>
  5. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I believe he meant the rear carrier from the old 10 bolt to the front 10 bolt with new 4.10 gears. BTW...I'm not sure
  6. rogerwilco71
    Sep 22, 2002
    179
    Central-Cal
    Shaggy's a fast typer /forums/images/graemlins/rotfl.gif
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That's what happens when your fat ass is parked at a desk behind a computer all day long. /forums/images/graemlins/eek.gif </font color>
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I believe the split on the 10-bolt is 2.56-down/2.73-up.
    Shouldn't be too much trouble to find used 4.10 gears w/case. Don't pay extra for thick gears for the case you have. Save your $$$ for a spool /forums/images/graemlins/grin.gif
  9. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Ok I'll go back to sleep... /forums/images/graemlins/ignore.gif
    Jim
  10. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    What are "thick gears"? I have never heard of this before. The front axle that matched the 14b sf i have was $500 cause the brakes were all new so thats why i didn't get it. Haven't been able to find another one thats why I'm going to put a ring and pinion in my current axle. /forums/images/graemlins/burb.gif
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    First of all, 2.42 in a truck?! /forums/images/graemlins/shocked.gif That's awful. Maybe you should double check. I've never heard of it. Even 2.73 is rare for trucks. 2.42 is a car ratio.
    The thick gear is needed because a low-number gearset has a huge fat pinion gear. There are almost half as many teeth on the pinion as there are on the ring. When you go to a large-number gear, the pinion is so much smaller that the ring is a hundred miles away. There is also such a thing as a ring gear spacer. Don't know if they are a good idea or not.
    A rear 10-bolt carrier does fit in a front 10-bolt. Everything inside the differentials is the same. The only difference is that there are no C-clips in the front, since they are not needed. There is room for them, of course, though.
    The one thing you should look out for is that all 10-bolts front and rear were 28-spline up to sometime in the late 80's when a 30-spline rear showed up. If your rear was 30-spline, you would have to switch to 30-spline front axle shafts to use that diff in the front.
    The carrier break is at 2.73
  12. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I think someone here is replacing the 3 with a 2.
    The numbers I know are 3.42 (and it is a very common number in 80' models ) and the carrier break number is 3.73, at least that is what all adds in my magazines say.
  13. u2slow
    May 9, 2001
    2,217
    BC Canada
    Each axle has its own unique carrier breaks. 10-bolts are not all the same! There's a 7.5" 7.625", 8.2", 8.5", 8.6", and of course all the Dana axles. Here's a link with most of the popular ones:
    Carrier breaks
