10 bolt carrier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by archer, Nov 12, 2001.
  1. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    I have a spare gm 10 bolt rear end. Is it easier to go through the hassle of measuring spring perches and shock mounts to swap out the whole thing, or would I be better off just to ditch my carrier, attatch my ring & pinion and pay to have the gears set up? Thanks in advance for your help.
    "who dares wins"
  2. dyeager535
    26,980
    Why would you have to change spring perches? Is this not a truck 10 bolt?
    Gear set up CAN be expensive, best call around on prices first. If you don't mess with the factory GM gear set up (removing, re-installing) it should last you damn near forever.
    If you ask me, the best solution if possible, and if you don't want to spend any more money than necessary, is to inspect whatever axle (complete) you want to use, make sure bearings and gears etc are in good shape, and swap it in complete.
    Either way though (swapping internals or swapping housings) they are used parts, with no guarantee on longevity. If you are easy on the truck, and have money, get new gears and bearings, and have the complete axle rebuilt. If you aren't easy on the truck, save your money and upgrade to a 14b now. : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I don't really understand your question ???
    The spare GM 10 bolt you have ......... is it from a 1/2 ton truck? If so, it should line right up, no problem.
    Are you asking about upgrading the rear to a 12 or 14 bolt or something?
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
