10 BOLT carriers ?
Discussion in 'The Garage' started by K10ANDYKHAMNIC, Feb 10, 2006.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Will front and rear 10 bolt carriers interchange ? :confused: that is all .
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  3. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    whoo hoo thank you . Confirmation please .
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Sure will. I did it on my neighbors truck a while ago after his Gov-Loc exploded
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    Thanks guys . :D
  6. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    yes it will friend has his gov bomb in his front after he got gears now it has 14 bolt and detroit and gov bomb up front
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes , and its the same carrier from highway gears to low gears .
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't think a TrueTrac can swap from front to rear...but I'm not sure.
  9. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i dont know about that but i think most all swap
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yes. However, you must match the spline count. Some are 28 spline while others are 30 spline. Unless you also want to swap axle shafts, make sure you have the right carrier for the job. :eek1:
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Correct. There are different part numbers for the TrueTrac, depending on whether it is for the front or the rear.
  12. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    good point i forgot to mention that
  13. readymix
    May 30, 2004
    6,706
    26
    just switch the spiders
  14. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Yes, carriers are the same. But there are 28sp. and 30sp. side gears. They interchange between carriers too.
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I've been told that it only works when putting 28 spline spiders into a 30 spline carrier. Supposedly the hole in the 28 spline carrier is too small for a 30 spline axle to fit through. :confused:
  16. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    That's correct, which is also what makes the 30 spline carriers marginally weaker than the 28 spline counterparts.
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have 30 spline front spares , and a 28 spline carrier on the bench . I should verify this sometime . but time is hard to come by after work !
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they will swap front to back and vice versa.
    ive got a nib 10b carrier 28spline in the for sale section f you need one :-)
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have carriers up, the wazooo , I just need to experiment and see if the 30 spline seven slide through the 28 :rolleyes:
  20. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its been a while since ive been in a 10 bolt, let along have the carrier out, but it seems that the hole that the axle goes in is huge and the side gears are what fill this hole in. according to everything that i have found, the major diameter of the shaft is the same, just 2 more splines.
