10 bolt clunker getting vicious
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newyorkin, May 29, 2001.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I just opened up my diff cover the other day, and refilled it with 80-90 gear oil. Now the truck is clunking into gear like it's hitting a brick wall (I literally looked around to see if I got hit by something when I first put it in gear).
    I had it clunking before, but not this bad, and it went away when I greased the TC output shaft yoke. All my bolts are tight, mounts are solid, driveshaft is tight.
    Should be expecting death from my axle soon? Is there a TSB anyone's aware of about the diff fluid needing anything special?? Should I have used something instead of 80-90 gear oil?
    Ratch
    **Hmmm. Land or Mall? Land or Mall? Let's see. Lotsa SUV's around here... Let's build a mall.**
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    This just my opinion here. I too have the engaging gear clunk. I have replaced the gears, still does it. Have replaced the u-joints, still does it. IT doesn't do it when the motor or tranny is cold.
    The only thing I can relate this too that hasn't been replaced yet is the chain in my transfer case. As it has 152,000 miles on it and I am damn sure it has some serious stretch ware to it.
    80w90 is the correct stuff.
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My 10 bolt clunked for about 2 weeks. First it was really low and quiet, then it got to the point where it was extremely loud and my rearend would actually jump. Felt like I was wheeling. My R&P broke off 8 teeth in a row... The big loud clunk was when it slipped once it got to the broken part.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  4. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    So I should be ready for it to blow up? Shoot. We're just about to buy a house too. Every friggin penny is going toward a down-payment. Anybody giving away a functional 10-bolt or 14FF (w/ a D60)???
    Ratch
