10 bolt corp?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, May 19, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    did they make a 10 bolt corprate rear axle. If they were made
    are they worth puttin in or will it be junk. I know a guy who says he has one he wants $50.00 I am just wondering
    if it may be a 14 bolt and he does not know it.
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yeah GM made them...There are weak,and depends on how you drive.What size tires are you running?
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    You can tell what kind of axle it is by counting the number of bolts in the diff. cover....
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yeah they make em cuz it's what I have....(until I can put a 14ff under it!) [​IMG]
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Corp 10-bolt was stock on most K5's, wasn't it?? cK5 has an axle-id chart that I find pretty helpful. Check it out <A target="_blank" HREF=http://coloradok5.com/axleguide.shtml>http://coloradok5.com/axleguide.shtml</A>.
    Ratch
    **Hmmm. Land or Mall? Land or Mall? Let's see. Lotsa SUV's around here... Let's build a mall.**
  6. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    what does the "ff" mean in 14ff? just wunderin'
  7. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    14ff = Full floater. Axle serves as a drive axle only. Carries no load.
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  8. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    what do you mean (i'm a bit slow)
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    On 10, 12, & 14SF (semi floater) the axle transfers all the torque to the wheel and supports the weight of the truck. A full floater has wheel bearings and a spindle like the front that support the load and the axle shaft only transmits the torque. Because the axle shaft on a FF only has one "job" it is much stronger.
    '71 Blazer CST with alot of rust
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Bah, my rear is a 10-bolt...and a full floater... =p I agree that the 10-bolt isnt the worlds greatest...but with the ff and 30-spline chrome-moly axels in there, its not too bad. I run 35s and with my lil 350 its not a problem. Just dont drive like an idiot and its all good. ;)
    J
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    10 bolts are not full floaters unless you got the Warn kit to convert it.
    BTW, please fill out your profile. You make it easier for all of us to fully understand what you have and where you are from. "Help us to help you". [​IMG]
    When In Doubt, Whip It Out!
  12. Hathaway
    Hathaway 1/2 ton status
    Jan 2, 2001
    295
    Missoula Montana
    Speaking of the full floater kit... I've got a 10 bolt rear. I don't do any hardcore off roading, no rocks, nothing like that. But I also don't want my 10 bolt grenading every time I get an itch to do some minor off roading. I don't want a 14FF for a few reasons, 1 cost in changing gearing, changing to 8lug wheels, and the size of the dang thing. And upgrading to a 12bolt, while I'm sure an improvement, would also probably require regearing and it wouldn't be THAT big of an improvement.
    SO any way, my question is, if I drop a Warn FF kit in my 10bolt, would it handle mild off roading with max of 35" tires? I've got a 305 now but I eventually would like a 350.
    Dan, '86 K5, 5.0L v8, NP208, TH700R4, open 10bolts front and rear, 3.43gearing, K&N filter, 31x10.50R15 Trailhandlers
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Personally, I have never experienced the Warn kit. Stephen Watson did on his green ORD blazer.
    From what I have heard and read, the Warn kit is better than the stock set up. You definitely should be ok with this set up and tire size as long as you do one thing: drive moderately. No hardcore, bat-out-of-hell, BANZAI, etc. driving.
    If you could locate a 12 bolt and install the Warn kit on that, then you are in a better league. Would you be changing the gear ratio? If so, then a 12 bolt would be a better candidate for the gear swap and Warn kit.
    I have experienced the 12 bolt myself and blown up a few. That was with hard and some mild off roading. I am not trying to scare you, but everybody is different. I have damaged three 12 bolts on 3 different trucks and that was enough for me to try out a 3/4 ton and also a 1 ton. I have never gone back after that. Just my .02 worth.
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    BigBrown - I'm in the same situation you are in. this is what I'm gonna do (sometime) I'm going to pick up a 14SF at a junkyard for an 81-87 3/4 ton PU, put new beaings, races, possibly a locker in it, and then do the swap. Plus, I'll get 4.10 gears. this whole thing should cost about the same or slightly more than the FF kit for a 10bolt. I'm going to take my time working on the 14SF while my 10 bolt is still good, and then swap them when I'm ready.
    90K5
  15. dyeager535
    26,980
    There are millions of 10 bolts out there. Hard core wheeling, doing burnouts, and driving crazy if it is a gov-lock rear axle, will surely result in destruction. Looked at another way, my 1983 K5 with 140K+ on it had the original axle assembly in it, and my K5 now has unknown mileage 10 bolts in it as well, and I have no concerns about breaking it when I go "off roading" hunting. Big tires and lots of power are going to break axles, while big tires with the gov lock are going to break the carrier. Spinning tires with an open rear axle (not posi) will result in rear axle destruction as well.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  16. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Since it is usually the gears or carrier that break in a 10 bolt, it seems like the FF kit is good money after bad in that axle. It will help you get off the trail when it does break though.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
